Question about Whirlpool Duet GHW9150P Front Load Washer
Pump is not taking water out of washer and making a terrible noise. I tried unplugging it, tried again, same problem. Door won't unlock to remove clothes. Is there a way to get the door to unlock? Thanks.
    Problem Solver:
  • 5 Answers
Dismantle pump and remove debis, check for excessive end play in rotor, you may need new pump
Posted on Aug 02, 2009
Door won't unlock whirlpool wFs1073dd front loader
If it has water in the the machine, it has a safety feature that will not allow the door to unlock. There is a manual release but you have to take the bottom kick plate off. Unplug the washer. Then reach up on the right side of the washer and you will feel a plastic lever about the size and shape of a nickel pull down on this lever to release the door. If it full of water i would clean the pump first to get rid of the water. you can clean the pump by taking off the kick plate and you will see a pump with a lid with a handle on it. you can unscrew this and it will have a trap attached to the back of the lid. pull the trap out and clean any debris out then screw it back in. make sure to have buckets and towels handy once you unscrew the lid any water in the machine will fly out at you. the easiest way to avoid this is to clamp the hoses that go to the pump.
Aug 24, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer started and now it stopped and it won't cancel/unlock and the door will not unlock. I have tried to unplug and replug and it still will not start or unlock the door. My clothes have been...
the most typical reson the door wont unlock when cycle is finished is because not all the water drained properly due to a blockage in the filter for the drain pump. This tip i wrote explains how to take apart the washer and clean the filter on the pump.
http://www.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
If you find the filter on the pump to be clear the door lock asm. will need to be replaced.
GENE
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
My Neptune washer MAH6700AWW won't unlock door and won't work. It stopped mid cycle and the door is in locked position. I unplugged and replugged and try to run a cycle but all it does is make...
Hi
It seems that something is clogged in the drain pump assembly and you have to clean it to solve this issue. After cleaning if the issue returns then test the door lock assembly, if bad it should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 07, 2011 | Washing Machines
Washer door will not open. Power button will not
You can manually unlock the door on this washer. First you should unplug the washer from the wall outlet and then remove the lower access panel. With the lower access panel removed, and the washer unplugged, reach up to the door lock and feel for a round release ring and pull it down. The door should unlock now.
Thank you !!
Jun 30, 2010 | General Electric WCVH6800J Front Load...
Door will not open, lock will not release - no error codes
buzzing noise would be a stuck drain pump. use a shop vac attach it to the end of the drain hose and remove all the water.then you acn turn the makcine on or unplug it for a few minues then pkug it back in this should unlock the door.once the water is removed, take off the drain hoses to the pump and look in to see what is stopping it from turning.if there is nothing blocking it the pump may be bad
Sep 24, 2009 | Samsung WF328AAW Front Load Washer
Making noise???
If it happens right away on the spin only setting, sounds to be something clogged in the pump....common things bra wires, hair pins, nails, screws..etc. Only way to access the pump is from the rear of the unit reaching through to te front....pain in the but to techs...I'd suggest if it makes the noise and drains slow to have a tech come out and fix your problem....but if you want an adventure unplug unit and empty the water, take the rear panel off and remove the hose from the tub(screw clamp) and reach inside with your fingures and see what you feel...may need to take hose completly off. reassemble and test with an empty load...fill with water and drain...be sure to check for leaks afterwards
Jun 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Door would not unlock - got an error code f-22 what does that mean?
your door switch may be going bad.try pushing the door in and hit drain spin and if that works then it will unlock.I need to know what code is flashing to help further.hope it helps.
Mar 05, 2009 | Whirlpool WFW9200S Front Load Washer
Washer stuck in Drain mode, flashes same time, can't unlock control or pause/stop
ck to see if any water in drum if so possible pump clogged ..remove bottom panel pump will have clean out port with large knob turn counterclockwise ..expect flood if water inside but can't be helped if washer is on pedistal open drawer and try setting bucket underneath and have towels handy..after cleaning reinstall port cover and try again..if no water in tub try unplugging hold power button down 20-30 secs and reconnect still have problem door can be unlocked by removing bottom panel and pulling small tab just below lock assembly from underneath
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The Maytag wahser stops and the door is unlocked
Something large in the drain pump could be the problem. You might need to remove it and take a look inside.
MAH2400AWW Frontload Washer drain pump removal link:
http://blog.myspace.com/index.cfm?fuseaction=blog.view&friendID=58843118&blogID=364038999
Jan 31, 2008 | Maytag MAH2400A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
