Question about Refrigerators
Will not make ice, light blinks when door is open and stays solid when the plastic square cover is losed. I get water to the dispenser in the door, it just will not make ice.It is a kitchen Aid Superba side by side with the ice holder in the door.
  • 288 Answers
Check the water supply tube going into the back of the icemaker and see if it is hard. if it is, water has frozen in the supply tube. If not, there is a dual valve solenoid located on the back of the fridge that the water supply hooks up to. It commonly goes bad
Posted on Dec 09, 2009
Ice and water dispensing intermittently on my Maytag model MF2568AES12 refrigerator. I replaced the light switch in the freezer, which didn't help. What should I do next?
On top of the fridge underneath the plastic cover for the door hinge probably on the door with the water/ice dispenser should be a wiring harness. This runs the ice dispenser and water. There should be a wiring harness plug there. Try unplugging it and reconnecting. This may be the cause since you said it's intermittent and with opening and closing the door it may be causing the plug to ever so slightly move around and loose electrical connection.
Oct 18, 2013 | Maytag Refrigerators
Ice dispenser delivers only crushed ice.
Make sure the dispensor door flap is closing completely .
Remove the ice bin , close the door , set the display for cubed and press the dispensor pad . Do you hear a " clunk " sound ? If not , open the door and press on the light switch , and activate the pad again . On the back wall , next to the " forks " , is a square hole with a white plastic square . Does this plastic square raise up ? If not , remove the top freezer door hinge cover and disconnect the plug there ( this removes power to the dispensor ) , you will have to remove the 4 screws holding this panel , and determine if the solenoid is bad , wire came off , or plastic piece is broken . If the plastic piece does lift , then the problem is in the ice bin . Lift the long rod , and see if the flap moves , where the ice comes out . If not , you will have to determine why .
Nov 03, 2009 | GE GSH22JFT Side by Side Refrigerator
Ice maker not working. water is loading but it never spits out the ice. The tray arm never lifts.
you need a new ice maker they typicallly only last about three years
you can check it by removing the cover (white plastic square on the forward end)
and place an insulated jumper wire from "T' to "H" it should advance (remember to hold door switch closed) if it does not advance then you need a new ice maker
Oct 08, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice dispenser won't turn on, and the ice maker won't make ice.
If you have a whirlpool icemaker inside of your freezer (I've read on other posts that whirlpool ice makers are installed in various makes and models), there is a white cover over the ice maker (it's square). Remove the square cover with your hands or stick a flat head screwdriver in the side until you can pull it off.
Once the white square cover is removed, you should see a white wheel with gear teeth. In the middle of the white wheel is a plastic snap that should be holding it in. I noticed that one of the little plastic snaps was broken...which caused my "no ice" problem. A simple test is to push the white wheel toward the icemaker. If the wheel starts turning, you have found the problem.
Because the little plastic snap tab was broken off, I was able to pull the white wheel out completely.
You see, behind the white wheel are metal contacts that need pressure for the ice maker to work. Without the center plastic snaps holding it it, the pressure is gone...and so is the metal to metal contact.
I previously called Whirlpool, searched all of the web...to no avail. Every other solution was "check for ice blocking the water tube" or "replace your water filter". That's all balony. If your regular water dispenser is working, you don't have an ice problem. And if your water dispenser is working, you don't have to change your filter either.
If you realize that the little white wheel is the culprit, just google "whirlpool module" and you will see it for sale. I found one on ebay for under thirty buckaroos with free shipping.
Hope this helps.
Mar 28, 2009 | Refrigerators
Side by side Whirlpool fridge with ice maker as well as ice and water dispenser in door. Dispenser works for both ice and water so water is getting to the system, but the ice maker has suddenly stopped...
Once the white square cover is removed, you should see a white wheel with gear teeth. In the middle of the white wheel is a plastic snap that should be holding it in. I noticed that one of the little plastic snaps was broken...which caused my "no ice" problem. A simple test is to push the white wheel toward the icemaker. If the wheel starts turning, you have found the problem. You see, behind the whhite wheel are metal contacts that need pressure for the ice maker to work. Without the center plastic snaps holding it it, the pressure is gone...and so is the metal to metal contact.
I previously called Whirlpool, searched all of the web...to no avail. Every other solution was "check for ice blocking the water tube" or "replace your water filter". That's all balony. If your regular water dispenser is working, you don't have an ice problem. And if your water dispenser is working, you don't have to change your fitler either.
Hope this helps.
Mar 24, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
then you either after doing this have a water to the ice maker problem, or an ice maker issue
go to the water valve and disconnect the small plastic line at the water valve and with a cheater cord connect it to the water valve, naturaly remove the factory connector at the water valve first and plug your cheater cord into the ac if you get water out of the valve the valve is good if you do not the valve is bad
if you get water out of the valve then you have a problem in the ice maker IF the line to the ice maker is clear and no obstructions
Apr 12, 2008 | KitchenAid KSBP25FKSS Side by Side...
Icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Nov 10, 2007 | Refrigerators
Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Nov 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
