Follow the link to the Netflix support website. https://help.netflix.com/en/node/46037
SOURCE: Can't turn on my wireless on my Samsung smart tv so it pick up signal on router
Suggestion: Use WPS on TV and router. It self configures. Worked flawless for me.
Good Luck
Have you tried using an Xbox Wii or Ps with your tv, cuz some TVs with build in Wi-Fi just never work right. Also plug it straight in to your router check in settings for an update, good luck
SOURCE: My Netflix has code: ui-800-3. Has been like this for a couple of weeks. Can u fix?
no
netflix has nothing to do with fixya site
contact your service provider and netflix for the answer
Quoting from link provided by yadayada
Sign out of Netflix
On the error screen in the Netflix app, select More Info or More Details and continue to Step 2. If you don't see More Info or More Details, continue below.
Navigate up and select Settings or the Gear icon and continue to Step 2. If you don't see Settings or the Gear icon, continue below.
Pull up the deactivation screen by entering the following sequence using the arrow keys on your device's remote:
Up, Up, Down, Down, Left, Right, Left, Right, Up, Up, Up, Up
Select Reset.
If you do not see Reset, select Sign Out or Deactivate.
Once you are signed out, sign back in and try Netflix again.
