Question about Whirlpool WTW6200S Top Load Washer
What causes Cabrio washer to get unbalanced in spin cycle?
What causes Cabrio washer to get unbalanced while spinning?
Every component and part replaced...still cannot finish spin cycle when goes off balance.
Whirlpool Cabrio WTW6200SWO washer
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Posted on Nov 01, 2009
Spin cycle is going on balance
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
Nov 11, 2016 | Washing Machines
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Whirlpool Cabrio gets unbalanced load at 7 minutes
Make sure load is properly sorted with like materials and paired up, do not mix things like towels with pants or shirts all together as different items absorb more water then others and can create unbalance when trying to enter final spin. If issue continues, it is very possible and item of clothing may have found itself stuck between spin basket and outer tub. This is very likely scenario due to design of this washer. If that is the case, spin basket must be removed then remove clothing to resolve issues.
Jun 02, 2014 | Whirlpool WTW6400SW Cabrio Washer
When the washer displays uL when spinning?
'Unbalanced Load' occurs when the machine detects that one side of the tub is heavier than the other.
This most often happens when heavy and/or large items become pushed to one side of the tub during the wash and become much heavier when the spin cycle engages.
This is more often seen in 'tub' style machines rather than front loaders.
Usually the machine has a safety system which shuts down the spin cycle and 'buzzes' to alert you to reach in and move things around in order to rebalance the load.
Jun 04, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Tub during the spin
It sounds like it may be a worn drum bearing. A loose transmission bolt could also cause the problem.
Dec 15, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio keeps giving Unbalanced Load message and has become very loud lately
Check your pump . make shore water is pumping out of drain hose fast/ if not clean objects in pump or pump impeller is broken? replace pump.
Feb 03, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer goes into spin cycle byitself and when washing,if u r in spin cycle it sets for 14 mins thats good 4 mins into spin all knob lights start flashing and the screen says uL
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
Jan 23, 2011 | Washing Machines
Whirlpool WTW6200S Top Load Washer Logo
1,204 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
