Question about Microsoft Windows XP Home Edition
I recently updated the downloaded windows movie make 2.1. Now I am having problems with my cd/dvd. When I try to save to a CD error message says "A recordable cd driver was not detected. Would you like to save you movie to you computer hard drive. I tried the fix it on line and also tried to reinstall the cd/dvd but it did not work. Can you help. Thanks, Debbie
  • 11,896 Answers
You will need to download the latest driver for your CD/DVD Player.
You can do this from device manager.
THen you can go to your F: Drive, click properties and make sure it is write enabled.
You can also use Media player to transfer to disc.
Posted on Aug 02, 2009
Why won't Xbox update?
To resolve this problem, try the following solutions.
Solution 1: Check your Xbox Live connection
If you're having problems connecting or staying connected to Xbox Live, see I get an error message when I test my Xbox Live connection.
If you still experience the problem, try the next solution.
Solution 2: Clear the system cache
Removing the temporary files on your console might solve the problem. Follow the instructions at How to clear your Xbox 360 system cache. Then, try downloading the update again.
Solution 3: Copy the update to a USB flash drive, CD or DVD
Copy the console update from your computer to a USB flash drive, CD or DVD, and then install the update on your console. Here's how:
Copy to a USB flash drive
Note The USB flash drive must use the FAT32 file system.
  1. Plug your USB flash drive into a USB port on your computer.
  2. Download the update file.
  3. Click Save to save the console update .zip file to your computer.
  4. Unzip the file:
  • If you are using Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  • If you are using an earlier version of Windows, you need to use a special software program to unzip the file (for example, WinZip).
  1. Copy the contents of the .zip file to the root directory of your USB flash drive.
  2. Unplug the USB flash drive from your computer.
  3. Plug the USB flash drive into a USB port on your Xbox 360 console.
  4. Restart the console.
  5. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Burn to CD or DVD
You can also download the update to your computer, burn the update to a CD or DVD, and then install the update on your console. Here's how:
  1. On your computer, download the update file.
  2. Click Save to save the console update .zip file to your computer.
  3. Unzip the file:
  1. Insert a blank, writeable CD or DVD into your computer.
  2. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  3. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
Dec 15, 2013 | Microsoft Xbox 360 Console
CDROM CANNOT READ MY ZUMA DELUXE CD. ERROR IS UNKNOW FILE TYPE.
I would say that windows is missing the codecs to play your cd. You can get the codecs by running windows update by right clicking on computer and then properties. and then click on the windows update and click get updates now.
An easier solution would be to download vlc player. It will play any file and cd or dvd. just google for vlc media player and download it and open the cd with VLC
Oct 19, 2012 | Microsoft Windows Xp Pro Professional...
Hi, I have a Toshiba laptop with Windows XP that was never connected to the internet. After I recently created a network, I kept getting a message asking me to install updates, as many were never installed...
This may be a system file that is being updated and has either become damaged or deleted. Try going to command prompt (hit start - run and type cmd then press enter) and enter the following command:
sfc /scannow
This is the System File Checker and it may fix the problem.
Mar 06, 2011 | Toshiba Computers & Internet
DVD-Rom will read the movie but won't write (burn) it. Bad block of memry
>> The Device has a bad block of memory, which Windows attempted to read.
Which CD/DVD disk are you trying to _read_ ?
Can you read this disk in a different computer ?
If not, then the disk is scratched or greasy or otherwise damaged.
Does the error occur when you try to start to _write_ ?
If so, the "blank" CD/DVD media may not be compatible with your hardware.
Find a "writable" disk from a different manufacturer, and try to write to it.
If that works, then you may need to do a "firmware-upgrade" on your CD/DVD-writer, to make it compatible with newer "blank" media disks.
Apr 25, 2009 | Computers & Internet
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Apr 21, 2009 | Magellan Maestro 4250 GPS
Roxio creator 2009 burning issues
Here's a few things you can try:
1.) Download Service Pack 3 for Creator 2009. This updates the software and is recommended.
http://www.roxio.com/enu/support/c2009/software_updates.html
2.) Update your CD/DVD burner drives. This can be done by going to the manufacturers website and checking for updates. (Ex: If you purchased your computer from Dell and it came with a built in burner, you'd check Dell.com for updates.)
3.) Update the PX Engine. This is Roxio software that communicates with the CD/DVD burner drives.
http://kb.roxio.com/search.aspx?URL=/content/000070GN&PARAMS=set-locale=en
4.) If all else fails, try visiting this KB article:
http://kb.roxio.com/search.aspx?URL=/content/000008GN&PARAMS=set-locale=en
Apr 04, 2009 | Roxio Creator 2009 for PC
DVD no video output
This was probably caused by an update,just reinstall your DVD encoder/decoder software.
Jan 27, 2009 | Computers & Internet
"0 not found" Error message when using DVD player on laptop
This is generally an indication that the DVD end of the drive is going out. First try a different or updated DVD decoding software. It could just be a simple glitch with the software, or that the software is outdated.
Jul 14, 2008 | IBM ThinkPad T43 Notebook
Not an Audio CD/Format Unsupported
Clean the CD and try again. Also, if DVD displays "not supported", call Bose and ask to recieve an update disc. These updates are released every 6 months. Document your remote control settings before loading the update as they may be erased by the update and will require re-entering settings after the update.
Dec 24, 2007 | Bose Lifestyle 38 System
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
