Question about Frigidaire Dryers
Frigidaire Dryer Power Cord Screw Size
I have a Frigidaire FDE336RES2 where the screws for the power cord are missing. Does anyone know the correct size screw to purchase to replace them?
2 Suggested Answers
tzweeb
  • 318 Answers
SOURCE: Screw Size to install electrical cord
they should be what is called a 10x32 screw. you should be able to get these from any hardware store. not at home depot or lowes, but like an ace hardware. they will know what you are talking about.
i would guess that someone lost your original screws. if not then you might be having problems because the screws got stripped out when trying to change the cord or hook up a new one. if that happend, then you will need to replace the nuts also. get them at the hardware store too.
it may not be easy but you will save alot of money if you can do this yourself.
Posted on Jan 06, 2009
What type of screws do I need for a Kenmore 80 series dryer power cord (where the three screws hold the wire to the terminal)
They are machine screws. Remove the terminal block and take it to the hardware store to match the size of the "lugs." Terminal Block 5304409888
Oct 14, 2016 | Kenmore Dryers
What size screw is use to install the dryer cord to the dryer terminal
Hello friend, thank you for allowing me the opportunity to assist you!
The screws that are used to install the dryer cord to your Frigidaire dryer terminal are stainless 1/4 inch screws. I hope this is helpful. -Matt
Aug 19, 2014 | Frigidaire FER641FS Electric Dryer
I am missing the wall mount screw for my TV.
The mount will come with several different sizes of screws so you can choose the correct ones.
Mar 18, 2014 | LG 50PQ30C 50 in. Plasma TV
Missing bottom case screws-need size
Sometimes there is a screw code next to the screw. Look at this code and then find a screw code with the same code, then remove this matching screw and yiu will be able to identify the screw you need.
Oct 17, 2012 | Dell Vostro 3500 Notebook PC Core i3...
Starter cord
remove top starter assy. cut grip from old rope ease rope into spool,
when slack remove center screw and carefully pull out spool, tie knot in rope and thread into spool, wind rope [make sure correct size rope]
around spool until full,carefully turn spool into spring 1 turn then replace screw. put rope into notch on spool and wind up 3-6 turns,
replace grip
May 19, 2012 | Mantis 2-Cycle Tiller
The power electric was run over by mower -unit has no electical power
You could bring it to a repair shop where they will probably install a new power cord. The now-shortened power cord can be fitted with a new plug, and used as before instead - for a fraction of the cost.
From what I can tell, the pressure washer is a 120 volt type. Purchase a replacement plug - called a "cord cap". The most common configuration is pictured below:
A 15 amp / 125 volt male cord cap made by Leviton.
Your's is likely rated at 125V/ 15A (like the one above). This means there's 2 parallel blades and a ground pin - like most grounded plugs in your home. If unsure, bring the cut off section of the power cord to a hardware store to select an identical cord cap. You'll want to purchase the type of cord cap that has terminal screws - not the type without screws. The packaging of the cord cap will indicate how much of the cord jacket and individual wire insulation to remove. A little more or less won't make it impossible to do - but don't deviate too much from these dimensions for the best results. Once the cord has been stripped correctly - Disassemble the cord cap body from the outer shell by removing the screws on the front. Loosen or remove the 2 screws at the cord grip end and slip the shell over the end of the power cord.
Bring the cord cap body to the cord. The body will have 3 screws. One each silver (or light colored), bronze (or dark colored) and green. Loosen all the screws - do not completely remove them. Twist all the strands of each wire so that they are bundled together and there are no stray wires sticking out. Do this for each white, black and green wires. The black wire will connect to the bronze colored screw, the white wire to the silver screw and the green to the green colored screw. You can either insert the stripped wires into the small holes at the back of the terminal screws, or wrap them around the screw terminals themselves. The best way is to wire from the back - but if you choose to wrap around the screws, be sure all the small wires are under the screw head. Tighten the screws and tug the wires one at a time to make sure they are held firmly in place.
Once satisfied that the wires are connected correctly and tight - slide the outer shell towards the cord cap body. Align the screws with the holes in the outer shell. The parts will only fit together one way - so don't try to force it together. Tighten the screws in the front and then install / tighten the screws at the cord end to grip the cord. This clamp should be firm - but not to the point of crushing the cord. Test in a ground fault protected outlet and you're done!
I hope this helps.. please rate this reply - thanks!
Dec 21, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Missing lcd screen screw
Hi, try this link. I think this is the size but you can check.
http://www.parts-people.com/index.php?action=item&id=5012
I hope this helps you.
Jan 25, 2010 | Dell Inspiron 1525 Notebook
Wrong screws
Hey there,
The screws for the tv are metric.
I would suggest the screws supplied with the shelf are not metric.
Try some new ones.
Sep 13, 2009 | Toshiba REGZA 46RV530U LCD TV
Dec 31, 2008 | Kenmore 659 Electric Dryer
Polaroid TV
You are correct. Polaroid does not make the screws available. You will have to obtain locally, per Polaroid.
Mar 05, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Dryers Logo
481 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
