Question about Maytag Washing Machines
I have a neptune washer model number MAH 7500AWW when i try to run a cold wash and rinse I get a very hot wash and rinse cycles.
    President:
  • 2,559 Answers
Sounds like the water lines on the rear have been installed backwards,Try a hot wash and feel the water as it enters and if it is cold,then just shut the 2 water valves off behind the washer and rearrange the 2 hoses that attach to the back.
Posted on Aug 02, 2009
Frigidaire Model # GLTF1670ASO rinse cycle is not working
ARE YOU WASHING IN COLD IF NOT YOUR WATER VALVE MAY BE BAD ONLY GIVING HOT CLOTHES WONT RINSE IN HOT
Jun 16, 2014 | Frigidaire ATF6000ES Front Load Washer
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Waher fills and then quits, won't start the wash cycle
LAT7300AAW that is your model number AZ103872 FD that is your serial number
Jan 02, 2009 | Washing Machines
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Neptune front load washer model # mah55oobww
you've got the hot and cold hoses reversed, switch them.
Oct 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
