Question about Clarion DB538RMP CD Player
Clarion db538rmp I just fitted second hand clarion db538 rmp and all was well until i tried setting it up and TEL came on the display and wont go off. I cant even turn off now. I tried disconnecting the power and re connecting but just comes up with TEL tried finding manual on internet but no mention of this problem in it
  • barry wright Dec 07, 2007
    This could have been the problem because i removed it overnight and it was ok when i fitted it next day. Thanks
  • Anonymous Apr 07, 2009
    i have the same problem! the radio is playing but when i move the car ... the TEL display come up !!
I had same problem on a different Clarion model.
it was down to brown (can be brown with orange stripe) telephone mute wire in grey plug causing a connection to ground. If you dont have a phone, Simple answer is remove the brown wire pin from plug, tape over it to stop any short, re-insert grey plug and it works...
Posted on Jul 10, 2009
  • 78 Answers
This proble is usually caused by the tel mute cable getting trapped as you push the radio in to the dash, pull the radio out of the dash and see if you can see if any cables have gotten caught in the cage
Posted on Nov 26, 2007
I have lost the instructions for my car radio and need to enter the code after the battery went flat. It's a Clarion PN-9939U (CH916) fitted into an 1996 Nissan Almera. I have the code but no instructions...
Clarion PN9939U Nissan Code Entry
After switching on the set ' CODE IN ' will be displayed.
Press preset 1 and the set displays '0000'.
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
To save the code press the [ ^ ] key. The set will now operate.
Nov 03, 2009 | Car Audio & Video
Clarion rdb465d display reads TEL after install, what does it mea
Hello rhowell2,
It sounds like the head unit has a ground on the "telephone" lead.
Make sure that all unused leads are taped off or otherwise insulated against touching other leads or the vehicle frame.
Hope this helps.
Aug 22, 2009 | Clarion DRB2475
I just install new Clarion BTL370 in the Clarion
A few things to check...
Make sure the receiver is set to "tel sw" or something similar in the menu. From there, you should be able to set the call to the left or right speaker. Make sure you set the headset to the same side.
Another thing to check, make a call and get connected through the headset. Now wait a few seconds and push a button on the phone to power the backlight. If it is wired correctly, you should see the "connected" timer on your phone keep time. If it appears that you are connected, the problem is most likely in the settings.
Also, if nothing else works, make sure that you have the accessory wire(should be red on the BLT370) connected to the right wires. All the other wires will power it on even if this wire is not connected correctly.
Jul 17, 2009 | Clarion MAX675VD Car DVD Player
Cant set clock on clarion drx5575
You hold down the sorce button and the display button at the same time. When the clock comes on you push the right button to set the minutes and the left button to set the hour.
Jul 07, 2009 | Clarion DRX5575
Need to fix time on Casio G-Shock
The hands are set independent from the digital display
Setting CASIO G-Shock Watch
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Apr 18, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Foot pedal won't work with hands free microphone
The 3750 won't let you control the telephone record jack. The only way you can get a mic to work using the Tel Rec jack is by pressing and holding the 'Tel Rec' button for about 1 second. But this isn't compatible with the hands-free operation.
If you're looking to do hands-free recording, it uses the built-in conference mic. Press and hold the 'Conf Rec' button for about a second and it should start recording. This built-in mic is located on the right-hand side of the machine near the front by the headset jack.
If you want to control the machine via a foot control while in Conference Record mode, you'll have to change the 'Foot Control Dictate' setting in the menu. Here's how:
1) Press and hold the 'Erase' & 'Search' buttons for about 5 seconds until the menu appears.
2) Scroll through the options until you get to 'Foot Control Dictate' and set this to 'Yes'.
3) Press 'Stop' to exit the menu.
4) Press the 'Conf Rec' button to enter record mode.
Now you should be able to control the start/stop of the record function via the foot control.
Hope this helps...
Apr 13, 2009 | Dictaphone 3750 Desktop Cassette...
Clarion DRB3675 cd and radio with clock
to set the clock just press and hold the DISP for 5 to 10 seconds, button while the clock is is displayed. When the the time starts flashing, use the DISP button to adjust the time. When you have the correct time, just hold the button until the clock stops flashing and you're done.
Aug 05, 2008 | Clarion DXZ665MP CD Player
Clarion DB245 CD player
I think you press and hold the band button then press the display button
Nov 19, 2007 | Clarion DB245 CD Player
Clarion DB538RMP CD Player Logo
487 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
