Question about Canon IXUS 960 IS Digital Camera
Won't turn on!
I had the same problem...thing is the camera doesn't even turn on now! The battery is fully charged, so I don't know what the problem is.
    Problem Solver:
  • 9 Answers
Had that problem too in October (during vacation in Sardinia); had to return the camera to Canon for repair. They noted a change of circuit ...
It 's now fully operational again
Posted on Dec 10, 2009
  • noorman336 Dec 10, 2009
    Could be this; it 's a known problem that they should fix under warranty (or extended/special waarranty or recall)
    http://www.canon.co.uk/Support/Consumer_...
  • 561 Answers
How often is the battery been used, it may be defective even though showing fully charged in the charger. a photo specialist or canon dealer should be able to test your camera with a new battery to see if this is the problem.
Posted on Nov 12, 2009
3 Suggested Answers
rollingaball
  • 5 Answers
SOURCE: my Cannon G9 digital
This is usually from a loose screw inside the camera, a screw inside the camera can come loose and cause a short which is very common on the G9. If you go to: www.camerasandparts.com all they deal with is service for the Canon Powershots. They're great if you need a hand with one of these and they automatically do the no power correction on the G7's and the G9's they service which is nice. They are about the least expensive out there at $89 and they include the service and the shipping back. The best part, they do excellent work which is a must for me. Hope that helps you some.
Posted on Sep 21, 2011
t00nz
  • 4738 Answers
SOURCE: Canon powershot SD1300 IS won't turn on, even
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on Oct 11, 2011
What cause the car want start even if u jump it it just cleick
Start with the basics, here. Check that battery cables are not loose and are CLEAN, on the battery AND the starter. Beyond that, check the battery charge with a volt meter. Fully charged should be 12.5 volts or higher, you will lose starter spin at 10 volts. If the battery is low, hook it up to a charger and charge it up completely. If you don\'t have a voltmeter, go to the store and buy one. If you\'re going to try and fix things like this, you have to have one. If you can\'t do that, remove the battery and take it to someplace like AutoZone. They will charge and test the battery for free. If you can\'t take the battery out, or don\'t have a friend that can, have the car towed to your mechanic.
Here\'s the thing- I can\'t tell you exactly why, but some cars you just can\'t jump start. Happens more on side mount post type batteries. Because you can\'t jump your car doesn\'t mean it won\'t start with a fully charged battery. Now there are other things that could be wrong with you car, that it won\'t crank over and start for you.....but we begin the diagnosis with the battery.
Mar 17, 2014 | 1993 Oldsmobile Eighty Eight
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Hello I have this Nikon Camera (N55) and it just wont turn on. A few months back it worked and now it doesn't. I have the right batteries and film so I was just wonderig if there was anything I could...
I'm sorry that the Camera is not turning ON. Please follow the below troubleshooting steps and check the operation:
  1. Please make sure that battery is fully charged.
  2. If the battery is not used for a while, it is possible that it may be damaged or completely discharged even if it was charged fully before. Hence charge the battery again and check the operation.
  3. Remove and Reinsert the battery and check the operation.
  4. Try with a different battery. If the issue persists with new fully charged battery, service may be required. You can click hear to setup a service for the Camera.
Thanks for understanding. Please let me know if you require further assistance.
Sep 10, 2011 | Nikon N55 35mm SLR Camera
My nikon s8000 wont turn on. It is fully charged, but will not turn on when I press the on button.
Jun 25, 2011 | Nikon COOLPIX S8000 Digital Camera
Camera will not turn ON. I changed the batteries but still no change.
Jun 24, 2011 | Kodak EasyShare M530 Digital Camera
My camera won't turn on i charged it and now it won't turn on!
This truly depends on the make and model of your camera. If it uses a rechargeable pack, make sure to fully charge the battery and try it. If this still doesn't work, try plugging it in the computer via USB. If it turns on, then your battery pack may be causing the problem. I would suggest you to bring it to your nearest service center for them to check it out, especially if you still have warranty and so they can replace the battery pack. Some cameras have a reset button at the very bottom (or look into your camera's manual if there is such a thing for your camera) which could be an option as well.
Jun 14, 2011 | Cameras
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even...
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
May 20, 2011 | Cameras
WHEN I CHARGE MY NIKON LITHIUM ION BATTERY THE LIGHT FLASHES FOR A FEW SECONDS AND GOES OFF. IT IS NOT A CONSTANT LIGHT WHICH IS A SIGN OF THE BATTERY HAVEING BEEN FULLY CHARGED. cAN SOMEONE TELL ME WHAT...
mcdevito75 here, Try a different battery in the charger if the same thing something wrong with the charger if not the same thing your, first battery is old and won"t take a charge. Age with these Batteries don"t really count, after so many charges they still have to be replaced.
Jul 03, 2010 | Nikon EN-EL6 Lithium-Ion Rechargeable...
It will not switch on, even with fully charged batteries
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 02, 2010 | Kodak EasyShare M853 Digital Camera
Canon IXUS 960 IS Digital Camera Logo
541 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
