I need a copy
I found that this site, https://www.astoriausaparts.com/copy-of-parts-diagrams , has the user manual for some of the Astoria Espresso machines. For the CKXE manual, click on the link for the CKX/CKXE parts diagram, https://www.astoriausaparts.com/ckx-ckxe . Scroll down to just above the Order Parts button. Currently, the direct link to the manual is https://docs.wixstatic.com/ugd/0a284f_9666875921c14e18b2706a74621e198b.pdf .
I hope this helps.
SOURCE: Caffe Nabucco BCO70 Espresso & Coffee Maker
go to this link http://www.delonghi.it/Int/USA/customer.html
you can download the manual
SOURCE: Astoria SAE-2
yes i found ur probelm . this might happen because of coffee deposites in the porta filter.
remove the screens with the help of the screw driver and wash it throughly .
then fix it again .
if still it is not working then , call me i will help u out .
ROhit PAtil
india
9766678617
SOURCE: Need Instruction Manual for Saeco Magic Comfort Plus
http://products.saeco.com/index.asp?id_paese=7
follow the link to the instruction manual
SOURCE: need manual/schematics for espresso machine.
Your coffee supplier will be able to provide you with one.
www.kaldi.com
SOURCE: how do I program an astoria SAE-2 espresso
Look behind the right steam valve, you will have to remove the front top panel, there might be a small toggle switch, note the position. If switch is not there then it is on the black CPU box. Press the program/stop button if all lights come on move forward if not then move the toggle switch to opposite side and press program button.
When all four lights are on press a button when you get the desired volume press stop, continue until buttons are programed then move toggle back to original lock position.
