Question about Cell Phones
How Can I use my PBH-8W bluetooth earpiece as a regular headset?
Hi everyone!
I have got a PBH-8W bluetooth headset which works perfectly with my mobile phone (= windows mobile, HTC MDA touch) for phone calls. I can also use it with my notebook just the way you would use a regular headset. Now I would like to use my bluetooth headset exactly this way with my mobile device (to listen to music e.g.). Unfortunately all the regular sounds and music go with my mobile's speaker while only phone calls are transmitted to my bluetooth headset. Does anyone know a solution?
Thanks in advance!
Dominik
PS: With regard to technical prerequisites it should be no problem: when I press the button at my bluetooth headset to enable ''voice control'', for a period of some seconds, when I am supposed to give a voice command, the music is switched from my mobile's speaker to my headset. Unfortunately it then goes back to the mobile's speaker at the end of the recording time.
keywords: T-Mobile MDA touch, HTC MDA touch, Windows Mobile 6, Wie kann ich mein Bluetooth-Headset wie ein reguläres Headset benutzen?, Kopfhörer, Bluetooth-Headset zum Musikhören
Need to replacement my hooks on my lg bluetooth
Home Depot pluming section. Size #36 O-ring will work. You need to use pliers to stretch it out before rolling it onto the earpiece but they work perfectly and will hold the wires better than the original clips. I show them in my repair video on youtube.
Feb 21, 2014 | LG HBS-700 Bluetooth Headset
If there is a battery in the earpiece; is it safe? There is some controversy about the safety of holding a cell phone to one's ear for extended periods; that's why I wanted an ear piece.
Yes it is perfectly safe. The easiest way to identify whether a bluetooth set is malfunctioning or unsafe is - HEAT. Normally batteries which are about to die or devices malfunctioning will heat up quickly when you charge it.
So unless you dont feel abnormal heat.. they are perfectly safe. Try to remove the BT earpiece when not needed. Your ear canal needs natural air flow. Blocking it with a prolonged use of a BT device could heat up the ear canal. That's where the problem starts! :-)
Mar 05, 2011 | Southern Telecom Emerson Bluetooth Headset...
XTM-1200 Drivers not found in laptop i need when i connect bluetooth to detect automatically the drivers for xtm-1200 model bluetooth headset
the answer is easy....buy a bluetooth device.....it will install a new software that is not in ur laptop...and it will work perfectly
Feb 18, 2011 | Radio Communications
The rubber part that goes in your ear has fallen apart but the rest of the 330 works perfectly. Need new earpiece.
I'm sorry, Plantronics does not offer a replacement ear tip for the 330 headset. I will include the link to a webpage for Bluetooth headsets below.
Plantronics Bluetooth Headsets
Good luck from Headsets Direct!
Feb 13, 2011 | Plantronics Explorer 330 Headset
The black rubber earpiece fell off my Plantronics Bluetooth while I was away from home. The device works perfectly, I just need to purchase a package of earpieces. Can anyone tell me where to buy these?
Plantronics has never sold replacement ear buds for the Explorer 330 Bluetooth headset. However you can call Plantronics directly at 800-544-4660 ext 5538 to see what options they may have available for you.
Feb 02, 2010 | Plantronics Explorer 330 Headset
Trying to connect my bluetooth to a new cell phone
turn on your cell; go to settings; find bluetooth settings;turn on bluetooth; find audio device choose search; then turn off the earpiece the light will be red next: turn on the earpiece again the light will flash blue and, the cell will find the earpiece the earpiece will flash blue slowly; once a minute
close the cell; use the earpiece
Sep 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
My iPhone 3G does not discover my Motorola H500.
Try this link. It solved my issue www.scribd.com/doc/280088/motorola-h500-bluetooth-earpiece-manual. Basically what you need to do is power the earpiece off. Make sure that your IPhone is not currently attempting to discover bluetooth devices (i.e. Bluetooth is OFF). Hold the On button on your earpiece (it has the symbol of a phone on it) for 6-10 seconds. The light on the earpiece remains lit. Now your earpiece is in discovery mode. On your IPhone, go to Settings, General, Bluetooth. Turn Bluetooth ON. Now your phone and your earpiece are both in discovery mode. When you see "Headset" listed, select it and enter the password "0000". Your IPhone is now paired with your H500 headset.
Mar 24, 2009 | Motorola Mobility H500 Wireless Headset
Earpiece slipped off the plantronics bluetooth,and i want to know if there is anything to help put it together again.
my plantronics 510 voyager did the same thing. try putting the earpiece back on to the main bluetooth and wrapping a small rubber band BETWEEN THE TWO. the object is to put some opposing pressure on the earpiece to force it to stay on. it'll work at least till you get anoter earpiece
Oct 05, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Bluetooth headset model PBH-8W
pass codes are nearly always as simple as 0000 or 1234 I have rarely seen any more elaborate than those have you tried those two?
Sep 24, 2008 | Plantronics - Bluetooth Headset Plus Base...
Programming bluetooth wireless head set model PBH-8W
If you need a copy of the instruction page, I can send you a pdf. ss061092@yahoo.com
Pairing your headset and cellular telephone:
1. Ensure that the headset is off.
2. Press and hold the multifunction button until the indicator light
turns on in blue (approx.8 seconds).
3. Set your Bluetooth-Compatible Phone to discover the headset by
following your phone's guide.
4. Typically, the steps involve going to a "setup"connect" or
"Bluetooth" menu option on your phone.
5. Select the option to locate, find or discover Bluetooth devices.
6. Press and hold the multifunction button on the Wireless Headset
until your cellular phone locates the device.
7.Your phone will find "-PBH-8W" and ask if you want to pair with it.
Confirm by pressing Yes or OK.
8.Your phone may ask for the password to the headset. Enter
"0000" (four zeros) for the code or passkey
9.Your wireless device will operate up to 30 feet from the wireless
telephone.
TECHNICAL ASSISTANCE:
Contact GNBI: GnbiTech@aol.com
Telephone
# 1-800-541-GNBI (4624)
Reference # PBH-8W
Sep 13, 2008 | Cell Phones
Cell Phones Logo
71 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
