Question about Refrigerators
Refridge side is not cooling, but freezer side is ok. Cleaned compressor screen. Top of inside of fridge is very warm. GE Model #ZISW42DYB cabinet side by side with compressor on top. What can I do?
    Problem Solver:
  • 5 Answers
Check to see if frostbound, or that the evaporator fan is not turning. you have an airflow problem.
Posted on Aug 02, 2009
Whirlppol Side by Side no longer cooling well.
I'd suspect a failed thermostat in the fridge compartment, a split and sagging door seal, or a fault on the microprocessor control if it has one of those.
Feb 10, 2015 | Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Refridge not cooling in freezer or fridge
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2010 | Maytag MSD2456G Side by Side Refrigerator
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge side by side fridge not cooling properly
So if you remove light fan will run? I can help if you get me a little more information. Thanlk Sea Breeze. Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Apr 02, 2009 | GE Refrigerators
Freezer is working good but the fresh food side is warm.
I will need to get a little more information to help you better. Sounds like the defrost timer is bad but I will need a number like for example 915.125869
Let me know, Thanks Sea Breeze
Feb 27, 2009 | Kenmore 53642 / 53644 Side by Side...
Compressor constantly on too hot to touch
hi have you cleaned the matrix best done by blowing with air but a soft brush can work,make sure that all the cooling vanes are clear
hope this helps ian
Jul 21, 2008 | LG LRTN22324 Top Freezer Refrigerator
Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Jan 25, 2008 | Refrigerators
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
