Question about Honeywell Programmable Thermostat Heater
Does blocking thermostat stop heating
Honeywell
  • 625 Answers
You mean like putting a box over the thermostat? the air inside the "stat" will get to a temperature and stop the heating. when the temperature inside drops, the thermostat contacts close again and the heater starts again.
Posted on Nov 29, 2007
5 Suggested Answers
  • 252 Answers
SOURCE: HONEYWELL T87N 1000 ROUND THERMOSTAT
the power for that stat comes from the furnace - if you have no display on the stat you have a furnace problem
Posted on Sep 28, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: installed my thermostat and the heat keeps
Make sure red wire is on R terminal, white wire is on W terminal. Also look for a short in the thermostat wire.
Posted on Oct 17, 2009
  • 118 Answers
SOURCE: Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Posted on Oct 28, 2009
Testimonial: "Thanks a lot for your help. I'll try that -- very simple!"
Therinnaiguy
  • 1420 Answers
SOURCE: I'm replacing an old thermostat with a new
Open up the propane furnace and see what color wires are hooked to the gas valve or circuit board. If it has a circuit board, note which color is on the R terminal and W terminal, Connect the the thermostat the same way. Most likely the yellow wire powers your A/C so you can hook that one to the Y terminal.
Posted on Nov 27, 2009
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Trying to install honeywell 7 day program thermostat but I don't know if I have a heat pump. My initial thermostat W white O orange G green R red C blue Y yellow. When I install the Honeywell the O is not...
Look real good at the terminal block. Look at both the left side and the right side of the terminal block. O should be there! You probably do not own a heat pump. Also have patients when programing the thermostat!
Dec 30, 2014 | Heating & Cooling
Honeywell TH8110U1003, No heat reading, only two dashed lines, please help asap!
Sounds like the tstat communicates with a wireless remote sensor on the heating unit. The dashes usually mean there is something blocking/interupting the signal. Maybe another wireless device signal crosses its path.
Apr 24, 2017 | Honeywell Heating & Cooling
I have a very old manual Chronotherm thermostat.
No. The clock is just the set back timer. Pull the battery and use the stat manually.
Jan 26, 2010 | Honeywell Electronic Programmable...
Model # RTH 1108 stopped displaying the
is my thermostat( honeywell rth1108) somehow to my attic fan. cant find a off switch for the fan. seems it is controlled by the thermostat.
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Central heating thermostat
Looks like it was replaced by the CM67 series, try this link for the manual:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
Geno
Feb 29, 2008 | Honeywell Programmable Thermostat Heater
My Heating system
Can you provide me with a make of the furnace and a model number if possible. They will be found on the heating system cabinet inside the unit, not on the thermostat.
Jan 16, 2008 | Honeywell Programmable Thermostat Heater
Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Jan 14, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
99 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
