Machine does not take water. the water does not come in to the machine. I think it can be the water pump.
  • Bruce Hathcock May 11, 2010
    be nice to know what model did you clean the input screens for it at the hose connetions?
    Problem Solver:
  • 6 Answers
Before breaking into your machine, shut off your water inlet valve(s) to the machine. Remove your water inlet hoses from the machine and aim them into the wash tub or a bucket. Check water flow through hoses. Debris in water system can clog up the screens on your water hoses.
Posted on Aug 04, 2009
E5 error on Onida washing machine Need solution
5E. This means the washing machine has a "water drain error". It's basically timed out on empty, it's tried draining out the water for 10 minutes and the water level still hasn't fallen below a specified level (or at least it thinks it hasn't). This error should be reset by pressing the Start/Pause button though if there is a fault it will need fixing or the error will just return.
A washing machine not emptying the water can have various causes as can a washing machine thinking it hasn't drained the water because it's possible that the signal telling the machine that the water has gone can sometimes not be triggered if a fault in the pressure system prevents it.
To troubleshoot this problem the first thing to check is the pump filter, which could be blocked. I have extensive advice on diagnosing pump faults here Washing machine won't drain water (stuck full of water) ' Faults on pressure system
May 17, 2015 | Washing Machines
I have a Hoover carpet cleaner that leeks the shampoo water onto the carpet, cannot control it
The machine is standing in the upright position with clean water in it. No power to the machine. If water is pouring out, again no power to machine, then the pump is cracked. I don't know the model number so I am thinking this has a gravity fed pump. It doesn't use electricity to work the pump. Once you pull the trigger water starts to flow. If the pump has a crack water will flow all the time. Hope this helps!
Jun 16, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Cycle does not advance?
it sounds to me like its a water pump problem i think you will find your water pump is not working. if the washer cant drain all its water it will not advance further than that as the machine must detect that all the water has been pumped out before it will start to spin. thus protecting the agitator from snapping.
Jul 02, 2010 | GE WBSR3140DW Top Load Washer
Hotpoint wma13 wont empty, think pump is blocked
Yes,
The water pump most be clugged and/or defective.
Aug 18, 2009 | Washing Machines
Think Pump or boiler broken as water doesn't flow through
If you cannot get hot water from machine(brew unit or steam valve), then there is something wrong with boiler elements.
If water won't flow thru coffee(pump is not vibrating) and you've tried adjusting the grind to a coarser setting, then you will have to replace the pump($50).
However, since no water is going thru machine and it does not heat up then the problem might be the board or the inline fuse on the machine.
May 16, 2009 | Saeco Vienna De Luxe Espresso Machine
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
Need to replace water pump
This is easier then most people think. You unscrew pump from trap door in front of machine. Then you tilt it back, be very carefull. There is a hole on bottom of machine, stick your head in there and locate plactic clip on bottom of water pump, push up and slide pump off, You will need to remove the hoses first.
Oct 22, 2008 | LG Washing Machines
Hoover 620 water not pumping out, motor working i think
hello zorro,
you can check your water pump filter assembly for debris and dirt or socks or small clothes.
sometime they do stuck in there and water pump i running but not pumping water out.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Washing Machines
PROLINE WASHING MACHINE W1000
i live in australia.i dont think it will be the pump but i could be wrong.
Mar 29, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
