Question about Sewing Machines
Top thread won't grab bobbin thred. It's a Kenmore Mini Ultra
  • 1,889 Answers
Re-sync the bobbin to the hook:
the needle should "pick up" the bobbin thread when the needle is about 1/4 inch below the hook move the mechanism slowly and, observe the interaction and you will see the adjustment screws on the carrier shaft you will need to adjust
Posted on Aug 02, 2009
  • Tennette Curry
    Tennette Curry May 03, 2014
    Where is the adjustment screw located?
Kenmore Ultra Mini Sewing Machine is jamming up
try a new needle--one that is correct for the fabric being sewed
make sure the top thread is not coming off the thread take up lever
clean in the bobbin area and under the plate where the feed dogs are for lint
Mar 26, 2016 | Kenmore Sewing Machines
My Kenmore Mini Ultra sewing machine won't sew the button stitch. I have followed the instructions on the manual but still the thread does not get sewn onto the fabric. Simple straight stitches are ok
it's possible that there could be a problem with the gear or cam that does the button hole stitch
try a different needle--one for the fabric being sewed
try a different bobbin --make sure the bobbin is not warped or damaged
try different thread-- use EVERY thread guide
make sure the bobbin is wound correctly--inserted correctly in to the bobbin case--and turned the right way.
May 14, 2015 | Kenmore Sewing Machines
Loading bobbin kenmore mini ultra
REPLACE THE NEEDLE AND INSERT WITH THE FLAT SIDE TO THE BACK OR TO THE RIGHT DEPENDING ON THE TYPE. HOLD THE NEEDLE THREAD WHILE YOU TURN THE HAND WHEEL. THE BOBBIN THREAD SHOULD RISE. IF IT DOESN'T THEN IT IS LIKELY THE NEEDLE AND THE HOOK (UNDER THE BOBBIN CARRIER) ARE OUT OF TIME. YOU WILL NEED TO VISIT YOUR PRO FOR THIS.
May 03, 2014 | Sewing Machines
My kenmore mini ultra is bunhching the tread by the bobbin
try changing the needle--normally flat side goes to the back of the machine
make sure the thread & needle are correct for the fabric being sewed
rethread machine top & bobbin
make sure top tension is adjusted according to fabric & thread
Apr 06, 2012 | PfaFF Quilt & Craft Pro 7530
Elna lotus
try cleaning under the needle plate & in bobbin area for loose threads or lint
try using a new needle--make sure the needle is inserted correctly in the needle holder
try rethreading the machine top & bobbin
if you try all these suggestions & the machine still won't pick up the bobbin thread then it's possible that the machine is out of time & would have to be retimed at a sewing machine shop
Mar 02, 2012 | Elna Sewing Machines
The bobbin thread wont come up when lowering the needle
The bottom thread won't come up?
Make sure you:
-Have the top threaded and through the eye of the needle (Basics are best to check, I've missed it once or twice! lol)
-Are holding the tail of the top thread when you lower your needle and pull it back up (Hold it too tight though, and it might not grab)
-Have an inch or two of "tail" or extra thread for the needle to grab on your bobbin thread (sometimes it won't grab if there's not much there)
-Have all your lower pieces in and secure. (Mine tend to jump around if I'm not putting 'em in right)
If it's still not grabbing, I'm not sure. Sorry, hope it helps.
Aug 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
Thread mess at the underside of the fabric
On the bobbin holder there is a smaal screw, thghten the screw to set tention on the bobbin thred. The thred you use on top and in the bobbin can be the problem as well E-Mail me wcbotha@yahoo.com
May 10, 2010 | Singer 8280 Mechanical Sewing Machine
My kenmore mini ultra sewing machine is stuck won't go forward or backwards. how to fix it.?
Take out the bobbin and bobbin case and make sure there is no thread stuck round the raceway
Apr 24, 2010 | Kenmore 11206 / 11306 / 11506 / 11606
Kenmore 15516 bobbin
1. Remove the bobbin case
2. Release the clutch by pulling out the handwheel
3. Draw the thread from the spool andguide the thread throught the hole in the bobbin from the inside to the outside
4. Put the bobbin on the bobbin spindle
5. Push the bobbin to the right
6. Hold the free end of the thread and depress the foot control, wind until full
7. Push the handwheel in (to wngage the clutch)
8. Push the bobbin spindle back tot he left to resume sewing mode.
9. Place the bobbin in the bobbin case (thread should feed clockwise)
10. Draw the thread through the slot in the bobbin case
11. Continue to draw the thread under the tension spring and through the opening Pull out about 4"' of thread
12. Holding the latch open position the bobbin case into the shuttle and release the latch
13. Case should lock into place when released
Hope this helps!
Bonnie
Sep 27, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
269 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
