Question about Maytag MDG7600AW Gas Dryer
My maytag autodry dyer mdg6200aww begins by heating up but the gas flame goes out after a minute or two.I checked for continuity on both the thermal fuse and radiant sensor and both checked out ok.
    Scholar:
  • 45 Answers
Continuity on the radiant sensor should be "closed" at startup, but it must also open after it has sensed the heat from the ignitor or flame.
The ignitor could be cracked and opening up after it heats up for awhile, also it's connectors might be loose/oxidized, clean them and reconnect after checking the ignitor.
Last thing to check is continuity on the gas valve coils. These two frequently go bad, especially the one with two contacts rather than three.
The set of two coils is about $10,00 on ebay. buy them and install. Even if you don't need them now, you will eventually need them. They are nearly a consumable item.
Posted on Aug 02, 2009
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Need to relight pilot light on MDG6200AWW gas dryer.
That unit has an electronic ignitor. You should not have to lite the pilot. There is no pilot to lite. If the dryer is taking longer then normal to heat. Check your vent to the outside. If the ignitor is not turning on it could be the ignitor, flame sensor and or thermal fuse. Check D.I.Y. Appliance Repair Troubleshooting to see if there is anything that can help you there.
Mar 28, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
Dyer is not heating maytag dryer D8000
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
rtw
Sep 02, 2010 | Maytag Dryer Lint Filter Screen 33002970
Gas dryer won't ignite. ignitor pulls 3.8amps. thermal fuse has continuity. flame sensor is working. jumped sensor no resultbesides checking outgas valve coil for ohms what other possibilities could...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Aug 31, 2010 | Maytag Dryers
I have a Maytag Atlantis. Model#- MDG7658AWW gas dryer. My issue is that the dryer starts to heat up ( the way it should ) at the begining of any cycle but cuts the flame after one minute & the dryer...
Problem is not with the thermals. You gas coils on the valve have gone bad. Replace both of them and you will be fine. Very inexpensive repair. Part number is 12001349 at approx. $45.00.
Jan 31, 2010 | Dryers
Dryer starts then flame goes out in about 15
Check that the lint filter is clean and that the exhaust vent is not clogged. Make sure it is clear all the way to the outlet. If no vent obstruction then the gas valve coils probably need to be replaced.
Sep 21, 2009 | Dryers
Maytag mdg6200aww dryer not drying clothes
my maytag dryer turns on the gas ignites and stays on for about 1 min then the gas shuts off the ignitor glows orange every 30 sec to a minute but the gas valve does not open also the dryer knob does not go past more dry im not sure if thats also the problem
Aug 24, 2009 | Maytag MDG7600AW Gas Dryer
Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
Feb 04, 2009 | Dryers
I HAVE A MAYTAG ATLANTIS GAS DRYER STOPS HEATING ABOUT 5 MINUTES IN
the flame going out is normal. the heat cycles on and off as called for by the thermostat. If the heat doesn't come back on i would start by changing the gas coils.
Oct 08, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
374 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
