SOURCE: error code e203
My sharp manual says E203 means "No broadcast now".
Under possible solution, it says " Check the broadcast time in the program guide".
My manual says nothing else after that.
I hope that helps. Please rate me. :)
SOURCE: in laymans terms ! got a bush 1080p tv, but when
1080P resolution is only avalable with BD players, Upconverting DVD players,Some media players and some satellite PPV movies.
SOURCE: infocus x6 has moving diagonal
Possible that the noise you seen( Video noise) is ccoming from the DVD player.
Most often the connecctingg RCA cabbles can be have poor shield orr damaged wires. So connect them tight with the ground tight. If the noise appears reverse the plug of the DVD after switching off.
If the fault wont clear, try to use another device on this port to confirm( another DVD player will be good.)
If the fault disappears then the noise is coming from the power supply of your player --possible failure of filter capacitorrs in the power supply,producing transcient voltage.
However if the other DVD also gives this noise, try to ground the projector, if there is no result then it is possible that the Video input socket has a ground failure in the board.( hope there is no issue with the PC)
If there is fault with all connections to the projector then it is possible that the board are not grounded or there is failure in power filtering. Check on power supply.
Hope these tips help you to make the tests.
SOURCE: How do you scan to email ? Please answer in
I will help you with this! Laymans terms are my specialty!
Turn on the PC & the printer
Make sure you have the printers software already installed before we go through how to scan to email. If you do not have the software installed, you can download it from Lexmarks website. After it is installed, follow these instructions:
Directions below are for a full page document only **
With the PC and the printer on and ready to go, insert a document face up in the automatic feeder
Find the button that has the picture of the scanner on it and press it. (Looks like a scanner with the lid open)
You will see the words "Scan to" appear on the display
The printer is asking you where you want it to scan the image to. You can scan to a computer, a flash drive, or memory drive.
Being you are going to scan your image to your computer to use in email, press the "ok" button.
Wait for the printer to bring up a list of applications that are compatible to send your image to.
Choose an application that you are familiar with by using the right and left arrow keys and then hit "ok". After you choose your application like Microsoft Photo ect., it will ask you what quality and size you wish to use. If your unsure, use the default choices that come up on the display by hitting the "ok" button after each one.
Then find the button with the green dot on it and press it.
This will transfer the image to your computer and you will see it on your screen.
Save it to your computer under a name you will remember. You can do this two ways. just hit the "X" to close the screen on the picutre and the computer should ask you if you want to save it and just choose yes. Or go to file at the top left side of the screen and scroll down to save as and choose a place and name then hit ok.
Open your email. Compose the email to the person you wish to send the scanned image to. Under the part where you enter the address and your subject there should be a picture of a paper clip. click on it and locate the name of the image file. click on the name of the file and then choose "ok" at the bottom. This should bring your image into your email and you will see the file name in the center area.
Write your email and hit send and your all done.
If you get stuck, here is a link to your manual for your printer that explains the instructions on how to scan to your computer.
http://www.lexmark.com/publications/pdfs/2007/7600/v7597795_en.pdf
SOURCE: i have a minolta CS
Hello this is going to be an issue with corona wires it could be the charge corna unit or the transfer seperation unit check the corna wires and springs that hold the corona wires in place if corona wire is bad replace also check for arching on the ends of the corona asseblys you can normally smell the arching or you can just replace the charge unit for the drum unit and the transfer seperation unit as well
