Question about Maytag Dishwashers
I have no lights or led on the control panel. I
I have no lights or led on the control panel. I have checked the latch switches with a multimeter and they both operate corectly. I have power to the one side of the switch. Is the problem in the control board interface or the circuit board? How do I verify?
    President:
  • 2,559 Answers
This is the control board,it will have lights when working even when everything else isn't so no lights mean bad board.
Posted on Aug 02, 2009
Door ajar alarm is on as long as the switch that controls the brightness of the dash lights is on. radio led is intermittanly off. 4x4 low led does not illuminates when selected
Every thing you posted can be read with a scanner. Not a code reader. If the 4X4 works, the LED is out. Replace the switch. I would live with it. The radio is the same except it is a bad solder joint. Door ajar is a switch in the door latch, inside the door. Some you can just replace the switch, some you have to replace the door latch. None of these have any thing in common.. Like a ground/fuse.
Jul 14, 2016 | 2004 Ford Explorer
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Washer doesn't start / lights up. Breaker is OK, electrical outlet too... What could be the problem ?? Control Board.. Fuse
More than likely it is the computer board. However it can be also caused by the main power switch or the door interlock switch. There is no fuse, the main power supply is part of the computer board. The switches are very easy to check but the front display panel of the dish washer needs to be disassembled as access to the main computer board is required. A multimeter it is also required for the switch verification. Make sure the main power cord of the dishwasher has been unpluged. Removing the front display panel it is not difficult. Once the front display panel is removed you have access to the main power switch and the door interlock switch. Unplug the power cord from the dishwasher and remove the connectors from both switches. Verify continuity on both switches using the multimeter. If you have electronics back ground skills you can also verify if the main computer board has power; for this you need to have both switches connected and the door interlock switch latched. You should be able to measure 110 volts AC on the two wires comming out of the main power switch connecting to the comptuter board.
Jun 08, 2014 | Miele 23 in. Novotronic G841 Built-In...
F5e1 error code
The F5 E1 error message indicates the latch motor was unable to lock the door. When the self clean cycle is started, the control board will turn on the latch motor which is mounted on the rear of this range. The motor is connected to a cam that transfers the motors motion to a rod that runs under the cooktop. This rod connects to the actual latch mounted behind the oven door. The control board will then monitor a position switch that is actuated by the latch motor cam. As the motor rotates, the latch will engage the door locking it in place just as the cam contacts the switch button. When the switch contacts close, the control turns the latch motor off and starts the cleaning cycle.
When diagnosing this failure, the error code gives us a good starting point to begin our trouble shooting. I removed the rear panel and started a clean cycle. Once the start button was pressed, the latch motor began to rotate, but didn't stop at the locked position. It continued to rotate three times and then displayed the error. I unplugged the range from the wall and using my meter, did a continuity check of the latch position switch (the one on the right). The switch was reading as an open circuit in standby and when I actuated the switch which tells me the switch has failed. The second switch on the latch assembly, by the way, is to turn the oven light off during the self cleaning cycle to protect the bulb. That way, if you leave the light switch on the control panel turned to the on position, that second switch will turn it back off. Good to know if you can't figure out why the oven light won't turn on.
With the failure down to the latch assembly, I checked the range parts to see if the switch came as a separate piece, but it looks like it's an entire assembly, and not individual parts. I removed the old latch after removing the two screws and six wires, then installed the new latchshow?id=y6f3ez5blva&bids=92089.709229668&type=10&subid=. Once all the wires were back connected to the proper terminals, I put the rear panel back on and plugged the range back into the outlet. Started a self clean cycle, but this time I heard the motor make one revolution and stop. The cycle started for the customer and a few hours later, I am sure the oven was nice and clean.
Aug 14, 2011 | Ovens
Oven is model 665.95781. I used the cleaning cycle.Oven door will not open. Message is E1 F5. Please help!
Based on your description, the E1 F5 error code likely indicates that the door latch is not operating.
Make sure that the oven door is closed when you start the Self Clean cycle. Check the door switch to see if it is apparently operating properly. Open the oven door and the oven light should turn on. Press in the door switch plunger and the light should turn off. If the light switch is not operating properly, it could cause this type of problem.
If the light switch is operating properly, then you could have a failed door latch assembly. A wiring failure or a problem with the control board could also cause this failure. I recommend that you unplug the range and access the door latch assembly at the back of the range. Pull the upper and lower back panels off of the range. Caution: The edges on these panels can be sharp. Protective gloves are recommended. With the panels off, check the wire harness connections on the door latch assembly.
Mar 20, 2011 | Kenmore Ovens
Neather rear electric side door will operate with the door switchs at the doors but operate o k with the console buttons up front or remote buttons. how do i fix ?
if i were you i would check all fuses for blown ones. once you have checked for blown fuses i would check the wiring with a volt meter to insure that it is fully functional the wiring on the doors will be easy to access if you cut into the wire coupling coming out of the frame.
Feb 08, 2011 | 2002 Chrysler Town & Country
Our Kitchen Aid Superba range has its door locked and the touch control panel is not working. The screen shows F5:E7 in the clock area. How do wee fix?
F5 - E7 Self clean latch will not unlock
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Sep 05, 2010 | KitchenAid Kitchen Ranges
The doors are all shut, but the dome light is not going off. indicator light showing door(s) open will not go off.
Most likely a faulty door jam switch. either this will be a little button near the door hinges, or can be attached to the door latch mechanism. the latter is a little more difficult to test because it can involve pulling the door panel apart. Try to find each switch and disconnect it from the circuit if possible to see if the light goes out. or try pulling out the switches and checking them to see if they are functioning properly with a continuity check on a multimeter. if all switches check out fine, the next steps are a little more advanced. Check the wiring from the switches for shorts between the wires that could be bypassing the switch all together giving it constant power. and the last, in rare cases it can be caused by a faulty body control module or similar electrical systems computer.
Jan 20, 2010 | 1998 Ford Taurus
Won't switch on
What brand TV is this? Sounds like the power board may be out. You could check for power at the power board with a Multimeter. You need to have power run to the TV but TV not powered on. Board usually has a led green or red light to indicate power to the board. Sometimes this light can be seen without taking the cover off, sometimes you may have to remove cover to see power board and definitely to test with multimeter. Hope this helps. J
Apr 08, 2009 | Televison & Video
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
27 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
