We bought it in 93, and it is still working, but everything has to end sometime, and when we replace it, want to get a little bigger one. Sears discontinued the manual and I don't see the cu ft on the tag anywhere. Anyone know what cu ft it is, or how to measure outside to determine? Appreciate it. DONR
Measure width ( across door) measure height ( from floor to top ) measure depth( from front to back) This the physical size of unit, shop accordingly. Also the cubic feet of unit is on a tag on inside of door frame. Bear in mind that the new units have more insulation so inside may be a little smaller.
SOURCE: fan is squeaking all the time Kenmore frost free upright freezer
Yes you need to replace it,if dont will have bigger problems.
SOURCE: small upright freezer (4 cu ft) is leaking water
Could be just the coils are iced up, I would pull everything out of it, unplug for a day, plug back in and let it run....
SOURCE: Trying to locate parts list for Woods 7.4 cu ft Upright Freezer
http://www.tradebit.com/filesharing.php/search/0/wc+wood/0/1
SOURCE: MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
SOURCE: ( upright freezer 17.8 cu
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
