Question about IBM ThinkPad T40 2373 Notebook
Audio line in
I am trying to upload music from vinyl disc on old style turntable, via twin [one red one white] jackplugs in line out sockets of amplifier leading to single jack plug in blue socket on T40 docking station. Am using Audacity software with guidance from Audacity Wiki.
It's not working. What am I doing wrong?
    Problem Solver:
  • 17 Answers
Do you have the line in volume control turned up and not muted ?
You need to go into Options - Advanced controls - of the volume control to get the sliders for all of the inputs.
Posted on Nov 25, 2007
Rca 5 disc changer rs2130i
Buy a lead with headphone jack to red and white RCA/phono. Jack goes to iPad/iPhone/MP3 player. Red and white goes to Aux/Game/Line input socket if the unit has one. Play your music.
Sep 01, 2014 | RCA RS2130i Shelf System
Crosley 2521
You need to get a special connector. Image of the type below. The red and white connectors connect to the RED (right) & WHITE (left) connectors of the turntable. The yellow is for video. Search Amazon for it.
Jul 06, 2014 | Crosley Audio Players & Recorders
Bad sound quality
You cannot connect the turntable via a microphone port. You need to connect via a USB port. If you have not got a USB port to connect it as the others are in use, you can buy an extension USB socket which, will allow you to put more devices via one USB port.
Sep 04, 2013 | ION Audio Vinyl Recording Turntable
Not all of the sound/music is being transferred from the LP.Hard to explain, but its when the LP has sound coming out of each speaker independent of one another, only one side is coming out on the recorded...
I know this is an old post, an I dont' have a solution yet, but t seems the same problem as on my Ion USB recorder - One of the input channels is not working. Like you, I found one of my music tracks not plying right - there was only the instrumental and no vocal. When I experimented, and changed round the jacks on the cable coming from the turntable (red and white plugs), I then got only vocals and no instrumental. Obviously one of the input sockets on the USB recorder is no longer working (I already checked the turntable and cable itself by playing back he same track with both stereo channels through my amplifier). You can either get the item replaced if its still under guarantee, or fix it yourself, if you have the necessary skills, neither of which apply to me.
Apr 22, 2011 | ION Audio Vinyl Recording Turntable
CAN I PLUG IT IN TO MY AMP
Yes the output jack socket can be used either to:
  • plug in a set of headphones for personal listening / practice
  • to connect to an amplifier.
The zoom pedals use either a mono or (tip and sleeve) or stereo (tip, ring. sleeve) 1/4 inch jackplug - i.e a standard guitar lead.
You should plug it into a line-level or high impedance socket on your amp. With the pedal in play mode you can adjust the output level (gain) to match the input requirements of your amp by rotating the 'Value' knob (top right)
Feb 26, 2011 | Zoom B1 Bass Multi Effects Pedal
I am trying to record my old vinyl records to a CD. I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling...
Complex? Traditional turntables need PHONO preamaplifiers (in receivers) to PREAMPLIFY the minute signal they produce to something useable.
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
Just curious, priorto the arrival of the RCD, how did you play or listen to the turntable?
Feb 26, 2011 | Sony RCD-W500C 5-Disc CD Recorder
I am digitizing vinyl. I cannot figure out how to connect this HE100 to my computer. phono has only in. turntable will not run through tape, which has record/audio out connections. it seems silly and...
Perhaps you should break this down into its TWO components:
1) Define the Phono source you're using. Is it an old-school turntable that REQUIRES a Phono Preamp conenction on the receiver to generate a useful level and quality of audio: or do you hae a new-age TT that can supply its own pre-amplified signal to ANY Line Level input; or do yuou have a newer-age USB TT that could connect directly to a PC via USB?
2) Anything that can connect to or pass through the receiver can be used as an input on a PC Sound Card via it's Microphone Input (if not via a specific analog or digital input). Run an RCA cable from the receiver's Tape_ or VCR-Out to an adapter that fits the Microphone Input if there is no RCA-style audio input.
Apr 25, 2010 | Panasonic SA-HE100 Receiver
Cannot burn to cd
hi... first you have to provide a pre amp phono for your tuntable to amplify the signal,,,then you cannot burn it directly the vinyl to cd as long you RIP the vinyl into your computer and then you can burn it into wav. files or mp3 files...please double check .u
Dec 27, 2008 | ION Audio iTTUSB Turntable
Connecting speakers to amp
Your Amp will be having a pair of Phono / AUX input sockets at the rear. Connect the two Red and White cabbles from the Turntable to these sockets. I am unaware of what are Pilot Speakers. regular speakers have a dual colored pair of cables coming from them. they have to be connected to the speakers Connectors at the rear of the Amp. Play a Vinyl Record, select Phono on your AMP, and enjoy your music.
Sep 15, 2007 | Audio Players & Recorders
IBM ThinkPad T40 2373 Notebook Logo
125 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
