Question about GE Washing Machines
How to adjust door on GE profile front washer.
How to adjust door on current model GE profile front washer. The door must be raised in order to make the latch line up.
the terrier
  • 94 Answers
SOURCE: DOOR LATCH DOES NOT CMPLETE INTERLOCK UNLESS PUSHED IN
hi billy
the most likely cause is probably the interlock switch has gained some play through wear an tear replacing it may solve it but first check that the door hinge hasnt been put out of alignment by the door being pushed open futher than needed. fitting a new interlock switch is relatively easy on most models www.espares.com might have it
hope this helps
Posted on Oct 26, 2008
MNTECH
  • 1543 Answers
SOURCE: GE front load washer WSXH208v1ww door latch
Unfortunately, the "door latch assembly" is what you would need. It comes with a new concrete front tub counter weight which is redesigned to not be able to contact the door latch switch on out of balance spins. It is also a lot of work to replace. (you can not get just the little plastic part) Please don't rate this solution, as anything but a Fix-Ya lowers my score, and I know you don't want to shoot the messenger.
Posted on Mar 08, 2009
jsrock516
  • 5911 Answers
SOURCE: Where can I find a door latch for the Kenmore HE 3t
"Fdl" is a door latch error code. This is an indication of either a defective door latch, door catch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, and the steps required to replace any defective parts. Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
Read through the information provided and post back with your complete MODEL NUMBER if you have questions. I hope you find this information helpful.
Posted on Jul 19, 2010
Macmarkus
  • 2605 Answers
SOURCE: GE front load washer WPXH214AWW.
Welcome to Fixya.
Based on what you've described,...and the part number you provided (WH10X10003)
It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **unplug the washer from the wall...safety first of course.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the new one and you`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
Thank you for visiting Fixya today. Good luck.
Regards,
Macmarkus :)
Posted on Oct 19, 2010
livewire874
  • 618 Answers
SOURCE: I have an ATF8000FS1 front
There is next to no adjustments so if the door dropped then the hinge must be bent . You may be able to very gently pull up on the door and re-align it but most likely you will have to replace the hinge.
Posted on Feb 26, 2011
GE Profile Arctica fridge running too cold
You may want to check your damper assembly to see if the door is broken. If the door is broken it will air to migrate to the refrigerator compartment causing freezing issues. Also check to make sure that the damper door is not staying open. When you take the cover off with the door open the damper should close. If the damper is open then you need to replace the damper. Here is the damper to order.
Dec 05, 2012 | GE Refrigerators
Re: GE Model TFX24R Side-by-Side 23.6 Cu Ft Refrigerator The refrigerator door needs to be raised to correct closure, it is visibly low and stands open. However, I have not been able to figure out how...
the cam must have broke and this is why the door fell,the cams are made of plastic,part number WR2X4901 and it's around 15 dollars,there's a couple of shims that are there too but they should still be good,
May 14, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
This is my second attempt. I have a GE Profile
After you set it, the display goes back to showing the current temp. Just wait awhile and current temp displayed should change to the temp you set once it has had a chance to adjust. Give it a few hours.
Feb 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
How do you remove the washer door
Thanks very much, but my husband found a way to remove the lid on the washing machine. There are 3 screws on each side of the lid that have to be unscrewed in order to remove the lid.
Jan 13, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
The rubber door gasket is torn, how to replace,
Get the model number off the washer
and go to appliance store who service or Sears
Jun 10, 2009 | GE WSXH208A Front Load Washer
GE Profile dishwasher door won't remain fully open and lay flat.
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
good luck!!!
May 06, 2009 | GE Dishwashers
On my GE Profile side by side the Fridge side the door will close and then pop open. The door has been making a clicking sound when opened. When it pops open it does not close again.
This can happen if the door gasket is not seating properly. If it is deformed you can correct this by pouring boiling water along the deformed area, then closing the door and keeping it closed while the gasket cools and sets. Please check first that it has been correctly installed, there are screws and a bracket behind the gasket. Another problem could be the alignment of the door. It is possible to adjust alignment on the hinges. One other thing is to raise the front "feet" so that the fridge slightly leans backwards.
Mar 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Model 22 , PTS25 SH SARSS
only a guess but the grill is not properly aligned
Feb 10, 2018 | GE Monogram ZISx420DR 42-inch Side by Side...
Washing Machines Logo
428 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
