Question about Scotsman Ice Maker 600LB CM3 30inW Commercial Cubed Machine
My Scotsman CM3 ice machine will not make ice. The "bin full" light stays on conatantly. I have held down the off button and ran through all the cycles and then hit freeze. It seems to want to then make ice but the comressor only stays on for several seconds and then everything shuts down. I have cleaned what I believe the sensors for the bin full function to work, I have unplugged it for days and same problem. I am lost, can some one help. The Make is CM3 Controller is a CM3 Universal Contoller , model # is CME256AS -1H
  • jeff bennett
    jeff bennett Apr 20, 2012
    The machine thinks it is full of ice.Look inside of bin if you see a white square plastic piece with a long tube inside of it that is a thermocouple that tells it its full.If you have that unplug it from pin 7 on controller it should work.If you dont have that you will have to replace the two ice sensing eyes. if you have the plug on 7 the ice will still stop when bin fills because the ice sensors will be blocked bin will just have a little more ice in it than normal.
  • 11,896 Answers
There is a bar on some units that will move when bin is full. This lever can get stuck and the circuits can go bad
Some units have a sensor that tells when the bin is full and that sensor or circuit itself can go bad.
Posted on Aug 02, 2009
Scotsman ice machine
Check the water inlet valve water seeping through valve should be running over into bin. Replace or rebuild valve. the machine should have slowed down on production of ice also.
Jul 17, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
How do i get a service manual?
The bin sensor eyes need to be cleaned or replaced. First remove the front cover then remove the white plastic ice deflector shield. Now you should be looking at the evaporator plate look down you will see the water sump tray full of water in that tray is a black plastic grate that when the ice is harvested it drops and hits the tray keeping it from falling in sump tray PULL it OUT. now just behind the sump where the ice falls through opening on the left and right sides is where the ice full bin eyes are you can pull them out side ways there is plenty of wire so you can pull them up to where you can clean them with a soft cotton cloth with scotsman cleaner. Now for a manual goggle scotsman service manuals you can get a PDF file.
Apr 28, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Where are the bin full sensors located for cme256ws-1c full light on will not make ice
The bin full sensors are located behind the water sump tray. Pull the front cover off remove the white plastic guard. Remove the ice deflector grate that is in the water sump tray. Now look where the ice falls down into the bin to the right and left side there is where the bin sensors are you have to pull them sideways you can also open the control panel and look where the bin sensor wire runs and follow it. pull the bin sensors and clean the eyes or replace them.
Jan 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Problem with Scottsman Ice machine. Not sure of model, but about a 600lb. Refrigeration light is on (steady glow, not flashing), not making ice. Air filters on either side have been replaced with new...
wave your hand infront of bin eyes if the bin full light doesnt blink the machine is not reading the ice fall during harvest and will cause it to kick out. basically it thinks its not making ice.
Sep 18, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
Where are the bin full sensors located for cme306as-1c bin full light on will not make ice.
It is a set of eyes located in the very back right and left hand side where the ice drops into the bin. Take some ice machine cleaner and wipe down the eyes. You should be able to pull the holders out to get to them better.
Jan 30, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Jul 17, 2008 | Scotsman Ice Maker 600LB CM3 30inW...
Refrigerators Logo
1,231 people viewed this question
Top Scotsman Refrigerators Experts
john h
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
