Question about Cub Cadet Street Sign- tractor lawn riding mower parts
After a period time, my cub cadet push mover won't start.
After about 1 to 2 years of service, my cub cadet push mower just won't start. It is a newer model (2000+). This is the second time that this has happened. Last time, the service department simply performed a seasonal checkup to get it working. Now it is doing its again.
  • 77 Answers
I would be a spark tester on first,see if your getting spark,mabey bad coil or wire. If your getting spark I would have the carb checked out.
Posted on Aug 11, 2009
I have a2011 cub cadet zero turn mower but when I push the left side handle it doesn't barely move . Like theres hardly any power to move the left side. What is a matter with it? Is going to cost alot
May be low on hydraulic Oil.
Theres also a nut that releases the hydro pressure make sure it is not loose. Make sure there are no leaks. And make sure on the back of the mover that the hydro release is not pulled. If there are no issues then there is a issue with the hydro pump and yes the repair is costly. A replacement pump is roughly $250-300 dollars.
May 21, 2015 | Cub Cadet Garden
How do I find year model on Cub Cadet rzt 50
The Manufacturers Serial and model numbers should be on a plate under the seat. Go to the Cub Cadet Website navigate to Manuals, enter the Serial/Model numbers and the year of manufacture should pop up.
Sep 21, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
How to replace belt model 2155 cub cadet engine pulley to deck?
Download the owners manual from Cub Cadet using model number 13A-244G100.
Customer Service Cub Cadet
Sep 16, 2014 | Cub Cadet Garden
Why won,t my toro z4200 zero turn mower go forward or back model#74360
Hi there, I assume the motor runs as usual, and doesn't cut out when you try to move forward or back. That would be a different problem than what I'm thinking about now:
If you look underneath at the transmission belt (this usually goes from the motor pulley to the rear transmission / diff) and see if it has fallen off a pulley, or disappeared completely. This would stop the forward or reverse drive of the mower. If this is the case, a new belt should solve your problem.
Jun 12, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hello, I have a Cub cadet tractor model 2164, and
BEARINGS ARE BAD IN CLUTCH REPLACE THE PTO
Oct 30, 2013 | Cub Cadet Garden
Cub cadet hydrostatic
brake lever on trans could be stuck on lay down and push lever to free up
Jun 04, 2013 | Garden
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 | Garden
My cub cadet model 12A-18M7010 will not start. It has an automatic choke. No primer. I've changed the gas, checked the plug, cleaned the carbuerator. What could it be?
Also check the air filter. Some times if the paper filter is wet or clogged it will choke out the machine by not allowing air in to the ignition chamber.
Apr 17, 2013 | Cub Cadet Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
257 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
