Question about Hitachi 32HDL52 32 in. LCD Television
Spare part tv is dead transistor 2SK3523 and T8C6F are defective where ican find them?
  • 405 Answers
Re: spare part
Try allied electronics and newark, both excellent service, may have to cross referance the part number though. I hope this helps.!
Posted on Jan 13, 2009
0 characters
3 Points
Tv will not come on. Red LEd flashes at the left bottom corner
Your TV is in protection mode meaning there's a defective part inside the TV. Sometime the symptoms is in the power supply or in the Horizon circuit. Probably a shorted transistor, IC's capacitor and open resistor or leak. Your TV need special attention by the service personnel you will not cost a lot. labor cost is fix. The problem is that... if the spare part is available....Dont worry the service personnel with provide everything to make your TV in good condition.
Sep 08, 2011 | Philips Flat Panel Televisions
Tv problem
It appears that the power supply is starting to fail on your LCD. Many failures like this one are due to bulge or leaky capacitors that overtime become defective.
Jun 26, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
No video and audio output.
if your TV unit no light power indicator that means dead set, check first the ac cord. and then open the cover the first thing you will check is the fuse replaced same rating if busted. your next step check possible loose contact and defective parts at power supply. leak capacitor, open resistor or shorted regulator IC and transistor can cause no power. just consider also the horizontal output transistor if bad. i can give you some basic tips on how to test parts if you don't have an idea.
Apr 11, 2011 | Flat Panel Televisions
My tv is dead , nothing at all , no sound-no lights nothing
that problem is in the power supply..
try to open the cover then look for the power supply if you see the power supply try to see inside then look for the fuse if busted?if it is busted check all the possible caused like power transistor called regulator.diode,transistor check if it is shorted..and also look for the leak capacitor and open resistor when you find defective parts replace it and finally try to test it again
please rate my answer if it is helpful thank you
Mar 09, 2011 | Flat Panel Televisions
My Mitsubishi LT 3050 now when turned on today has no picture. seams that your tv is high heated or it is needed to change some of the transistors... just replacing ur transistors with the help of some tv tecnician would solve ur problem...
thank u rate me!!
Feb 10, 2009 | Mitsubishi LT-3050 30 in. HDTV LCD...
Astar LTV_3001 flat panel tv power supply is not giving me the 16V I need to run the audio amplifier. I need the identity, type, something on the Q12 transistor. This transistor is also linked to an...
Hello Sir,
I need paciffic how's the TV defective (problem) so you have fix all the transistor and the capacitors then what happen next? still can't resolve your problem? unit still not right? call me at 323-767-6030 maybe I could help you through.
Jul 30, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Tv wont turn on
This could indicate a variety of problems, some of which might be relatively simple for a technician, others more difficult to diagnose and repair. Most all do require the expertise of a visit to a repair technician. A dead set symptom as you have is often caused by a short in the horizontal deflection circuit (shorted horiz. output transistor), or short in a section of the power supply.
If you have some basic tools/equipment, including digital or analog VOM, you could take the back off the set and do some checking. Find the horizontal output section, and check the above noted transistor, also looking for bad solder connections in its associated and nearby circuitry. Bad solder connections are a common defect in numerous sets, and also cause dead sets, and sometimes can cause a component failure.
It is obviously a plus if you can come up with a schematic.
Beyond this, take it to a qualified technician.
Apr 13, 2008 | Flat Panel Televisions
Sharp Aqueous 37" LCD TV
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Apr 08, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Plasma Tvs
When switching to STBY raster remains and buzz noise is heared from the speakers
Cause: +B voltage (103 V) does not switch-off. Remedy: Replace defective C541
Ticking noise and line in picture
Transistor 7381 (BC848C) defective when hot
Dead with ticking noise from line
Replaced C622, C604 and Q509
Nov 26, 2007 | Flat Panel Televisions
Samsung flat screen plasma tv 40" with intermitent problem
Many of the parts in these sets are proprietory. The manufacture reps generaly change the complete board to service the sets.
The can be failed and you change them, but you would have to also find the cause of the failure. If not, when you apply the power back again, the new parts will fail again!
Jerry G.
Jul 12, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Hitachi 32HDL52 32 in. LCD Television Logo
119 people viewed this question
Top Hitachi Flat Panel Televisions Experts
Are you a Hitachi Flat Panel Television Expert? Answer questions, earn points and help others
