Question about Kenwood KDC-138 FM / AM Receiver
Kenwood KDC-138: Removed Old stereo, installed new KDC-138, I'm getting power to the plug that plugs into the back of the unit & fuse is good. I've tried pushing the reset button. Nothing comes up on the screen. You can't even tell that the power is hooked to it. Same thing happened yesterday, thought it was a bad unit & returned it this morning only to have the same trouble. This leads me to believe it's some type of security code or something programmed for shipping. Is there a start-up sequence that I'm not finding in the manual?
  • Davis Johnson
    Davis Johnson May 11, 2010
    I don't know if this helps anyone else that might know what's going on, but I've got the same problem. In a '97 Dodge Dakota, I took out my old (Alpine, not stock) radio, spliced the new plug onto the wires, and then connected my Kenwood up to that and the antenna wire, and you can't even tell that there's power going to the unit. I'm sure all my splices are good and that there should be power going to the thing, but there's not.
Mine did the same thing when i first put it in, for some reason the only way my radio would get power is if i connected the constant power wire and the ignition power wire from the radio to the constant power wire and ignition wire from the truck all in one connection
Posted on Jun 18, 2010
  • Baloftw May 20, 2011
    Same exact issue. Not sure if it was the wiring harness or what but I had no voltage coming from the vehicle's red 12V line. Connected the stereo's red and yellow 12V inputs to the truck's yellow 'always on' 12V feed and it worked like a charm. Just remember to turn the stereo off when you exit the vehicle or it will run until the battery dies.
  • 8 Answers
Do you have power at both supplys on the wire harness?( red and yellow) red wire will have power with the key on. Also make sure your ground is hooked up right.
Posted on Sep 15, 2009
How to install a Kenwood kdc 138 in a 1992 Ford Escort LX?
if its anything like my 92 ranger you take the dash apart around the radio and the stereo should unscrew, in my ranger the new cd player went in without any extra harness as it was the same size as the stock, if not you can but harnesses to go where your old stereo did, to connect the speakers you can buy a ford wiring harness from walmart or any store with an audio department. these plug in to your vehicles wiring harness so you don't have to cut it out, after that you simply match colours from the wires of the new cd player to the wiring harness
Dec 25, 2013 | Kenwood DISCONTINUED - KDC-138 In-Dash CD...
Have a kdc-138 radio which wire do i attach the remote wire to get power to my amp
hi robert, attach your remote wire from the amplifier to the blue/white striped wire of the harness of your kenwood unit. the wire should be labelled "p.cont". cheers!
May 22, 2012 | Kenwood KDC-138 FM / AM Receiver
I just purchased a new kenwood KDC-138 head unit as well as two car speakers. The speakers were able to be installed onto my 2000 mercury cougar but the head unit gave me some troubles. The wires on my new...
The following will help you out. The first is for the vehicle and the second for the stereo. Good Luck.
Constant 12V+ Orange/Black Switched 12V+ Yellow/Green Ground Black/Green Illumination n/a Dimmer White/Green Front Speakers 6" Doors Left Front (+) White/Black Left Front (-) Gray/Black Right Front (+) White/Red Right Front (-) Gray/Red Rear Speakers 6" x 8" Side Panels Left Rear (+) White/Purple Left Rear (-) Gray/White Right Rear (+) White Right Rear (-) Gray
May 16, 2011 | Kenwood KDC-138 FM / AM Receiver
Don't know how to set clock on kenwood kdc-138 without manual
change the tune mode to standby mode. Then press menu button for few second until clock word is displayed on the screen. Afterward, press the center of the main control button on the right side of the stereo system. The time is now blinking and you can start set the time by pressing upward & downward button for hour and left & right button for the minute
Mar 14, 2010 | Kenwood KDC-138 FM / AM Receiver
I have no sound
just because the wire loom looks the same doesnt mean it is check the manufacture's website for any information you can find.
Feb 14, 2009 | Kenwood KDC-V6017 CD Player
Kenwood KDC-138 Standby Question
Standby mode does not completely power down the unit it jsut does not draw as much power as when the unit is on. Also, depending on the unit, it might start back up faster in standby then from power off. You can select to have certain things displayed while in standby mode. Here is what can be selected for this unit:
Standby: displays CD loaded indicator, "STBY" indicator, and clock (when selected)
Hope this was helpful.
Oct 29, 2008 | Kenwood KDC-138 FM / AM Receiver
Kenwood KDC-138 Operation Problem
Here's the quote from the manual regarding "dcer": "The speaker wire has a short-circuit or touches the chassis of the vehicle and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT/DCER" code does not disappear, consult your nearest service center "
I believe the manual can be downloaded from crutchfield .com after you go to the Kenwood KDC-138 page on their website. The reset button is either on the lower left of the face or, removing the face, on the lower left of the body. Hope this helps you.
Jul 24, 2008 | Kenwood KDC-138 FM / AM Receiver
My car stereo
Check the fuses
Oct 06, 2007 | Car Audio & Video
Kenwood KDC-138 FM / AM Receiver Logo
468 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
