Question about Kenmore Elite HE4 Electric Dryer
HC error code 110.27087603
Any idea what this code means? The washer seems to work fine, but clothes are slightly more damp than usual. Also, any clue on the matching dryer (110.67087600) F44 code?
  • Anonymous Sep 25, 2008
    Same problem washer finishes cycle and says HC.
  • Anonymous Dec 15, 2008
    same problem
Where is the pump located
Posted on Jan 16, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Washer...check the pump unit and your manual...should have a code listing in there
Posted on Jan 02, 2008
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
I have a 7 year old electrolux edc 5330 clothes dryer. The dryer seems to run normally - there are no weird sounds or error codes. However the clothes dry poorly. I have to run the most efficient drying...
Remove the dryer from the vent leading to the outdoors and try drying a load. This will reveal a restricted external/internal exhaust. If it dries in a normal cycle, it means the duct to the outside needs replaced or cleaned.If it still takes too long, the washer may need some maintenance to make it extract more water. If none of the above resolves the issue, the dryer will need to be disassembled inspected for worn, parts/air seals, etc. Follow the link below for disassembly instructions
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Oct 20, 2017 | Dryers
Clothes seem too damp after final rince
its a washer ,not a dryer....if the spin setting is set low the clothes will feel quite wet....reset to a faster spin cycle if needed.
Jul 26, 2010 | Whirlpool LSQ9549P Top Load Washer
What does it mean when the washer goes all through its cycle and says clothes are clean but has an error code displayed saying HC??
Interesting. Lets look at the TECH SHEET. HC hot cold reversed. The inlet hoses are connected bass ackwards. Connect the cold to the COLD inlet and the hot to the HOT inlet and the on board processor will work much mo betta I garontee. As shown on page 5.
Jun 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Duet 9100 will not drain during regular wash cycle. Cleaned drain filter & ran diagnostic and then rinse & drain. Water drained from washer & clothes were damp and I thought the...
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
Mar 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Nontypical F02 error
error code f2 is a pump issue,, repl/ or clean out pump
Jul 26, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
184 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
