Question about Refrigerators
The fan blowing the cold air seems to have stopped.
    Champion:
  • 363 Answers
That fan is called the freezer fan, It costs parts and labor around $300.00
Posted on Aug 05, 2009
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
On my wifes 2006 chrysler sebring air blows cold and hard in town once on the highway it seems to stop blowing hard , its still cold it gets loud like the air is blowing but , just not all out the vents
Do you live in a High Leaf Area? The Cabin Air Filter could be blocking the system. Additionally, there is a resistor that is common on Dodge's to go bad and cause the fan not to work properly.
Apr 05, 2013 | Chrysler Sebring Cars & Trucks
Weird problem, 2005 Kia Spectra5, after air conditioning or defrost is running for about 15-20 mins, seems like the air stops blowing, even though the fan is running, turn the heat settings to fan for...
you may want to check and see if the cycling switch is defective...it engages and disengages the clutch on the compressor ..i would check and see if the clutch stops engaging when the a/c starts blowing warm
Feb 08, 2011 | Air Conditioning and Heat for Kia Spectra5
Whirlpool fridge not blowing cold air but freezer
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
May 28, 2010 | Refrigerators
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
I have a sunbeam 12000 btu window unit air conditioner. I can't seem to change the fan speed when it is in cool mode. When I put it on fan only it blows extremely cold air and i can change the fan speed. ...
Sounds like the switch is wired wrong.
When you put the switch on fan only the compressor should not run at all, therefore their shouldn't be any cold air.
Check the switch to see if it's wired right.
Jul 29, 2009 | GE Profile ASM10AA Air Conditioner
A/C blows hot air intermittently
this is clear that your aux fan cooling your condensor is not working ,your a/c system is overheating and with speed you are forcing air through your condensor doing the job of the fan.
Jul 21, 2009 | 2003 Chevrolet Silverado 1500
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
