Hi Darren, I have Sky (foxtel) and the Sky box (foxtel box) is hooked up to my television and the only thing is i turn the volume up to full on the television and control everything (volume and change channel) through my Sky(foxtel)remote control..... I hope this helped, CHEERS..
It will be best for you to download the user manual to your TV. www.retrevo.com/
Check this site to download it for free. It has all details. Electro help
Does the Foxtel unit operate a cable box or convertor separately? You remote should be setup (Foxtel) to turn both units off at the same time. It sounds like the Foxtel unit is losing all of it's power when it should have constant power for standby.
Press setup on your foxtel remote, go to systems settings, and look for "TV Type" menu, you can change settings there, your TV is a 4.3 (square) not widescreen. Its not a telly problem your just giving it the wrong signal.
Hi Gerald P, just posted we experienced same problem. Few minutes later my husband has finally solved our problem. Don't know whether you can try the same. We had an old FOXTEL remote, got onto FOXTEL site and instructions how to program remote to control TV.
Dowloaded instructions with code for TV (after trying a few tries, the fifth code solved it). FOXTEL control needs to be programmed with the code suitable to TV. By pressing "ON", "AV", Red button and Select (at same time) then put code in. Turn "OFF" then "ON" see if code complies. If not try another one until you get it.
By using the FOXTEL remote on the "AV" you can change the channels on the TV and adjust volume up or down as well.
Hope this can help you in your situation. Glad we are up and running again. Bye
