Question about Jandy Ray Vac Pool Cleaner for Inground Concrete
Ray vac circles drain, miking left turns
Stalls at high end drain
  • 990 Answers
Could be something as simple as the direction of your return jets in pool creating a current in pool or more likely a hole in hose or stuck back up valve. If you pull the whole unit and take it to your pool store they will usually check it out and fix it just for the price of the parts.
Posted on Aug 24, 2009
I have a jandy ray vac pool cleaner that just goes in circles in the deep end of the pool.
look at instruction manual there is a setting you probably have to set
Jun 01, 2014 | Pool & Spa
My cleaner doesnot come out of the deepend and circles toth left
These automatic pool cleaners are pretty easy to troubleshoot. Make sure that the finger screen and energy filter are not dirty. If clogged or obstructed, both of these can cause the cleaner to go in circles and stall. Make sure that the backup hydro-timer is not releasing most of the water out of the discharge hole. If it is, you will probably have to replace the defective jet gear assembly. Make sure that the transporter jet is not plugged and that the debris chamber and hose are not obstructed.
Jun 02, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Goes in circles
you have a clogged line. disassemble and clean it very good
it should work fine after cleaning all ports out
May 24, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Ray Vac Pool Cleaner for Inground Concrete: Our Ray vac worked well for years but now it tends...
If your automatic pool cleaner is going in circles, you might want to check your backup hydro-timer. If it is releasing most of the water out of the discharge hoke, you might need to replace the defective jet gear assembly. Also, make sure that the transporter jet is not plugged. Check your hose to make sure that there are not any obstructions that would prevent proper movement.
May 18, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Ray Vac Pool Cleaner for Inground Concrete: after cleaning out debris from my ray vac my jandy...
What model is it? Is it robotic (indepentdent of your pump and filter)? If it is attached to your pump system, it could be the cord getting tangled and causing the pool cleaner to move in circles. You might want to consider running it when you are available to watch it or getting a robotic cleaner that you can set to operate at certain times. You might just need to check the hose for defects that would cause it tangle.
May 17, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
My Ray Vac is 2 years old. What is their average
You should be able to get your pool shop to rebuild this for you, usually just for the cost of parts. Then you should take it in to them once a year to be checked as prevention is worth more than cure. Good luck.
Dec 19, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
RAY VAC GOES IN CIRCLES
Change the pusher hose, the pusher jet, and the pusher jet sleeve. These are the first things coming from the end of the unit toward the wall. If you replace all of these parts and it continue to circle, change the front wheel.
Aug 10, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
I have the problem of the circling Ray Vac. And I haven't seen any solutions here. What's wrong, and what do I have o do to fix it?
PRESSURE is King. After taking apart my entire Ray-Vac and hoses, nothing seemed to fix my circling problem. I finally performed a full cleaning of all my mechanicals, especially the paper filter. I noticed a significant improvement in my water pressure and my Ray-Vac starting running all over the pool again doing her job like she used to. So, the Ray-Vac is very sensitive to water/jet pressure. Check your filter system. You want the most pressure you can get of out jet where you connect the Ray-Vac. This completely solved my problem.
Jun 07, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Runs in a small circle
A couple of things to check. 1. sometimes the hose at the back of the head will develop a small hole or crack where water will escape and cause the vac to run in circles.
2. if the head is getting old, you might have enough wear that the little wheels on the bottom stay mostly in one location, pushing in one directon.
May 15, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Ray Vac moving slow, circles deep end, sticks on side of pool
I have the same problem and the best solution is to repair/replace the hydro timer kit. It has inner gears that are plastic and wear down and doesn't rotate through the cycle of water flo that changes it's direction. I'm in the process of exhaustive repair and I'm going to replace the hydro timer - (inside part only) and then see what happens. Moving the gears did change it's moving patterns tho.
Dec 19, 2008 | Jandy Ray Vac Pool Cleaner for Inground...
Jandy Ray Vac Pool Cleaner for Inground Concrete Logo
188 people viewed this question
Top Jandy Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Jandy Garden Expert? Answer questions, earn points and help others
