SOURCE: goodman furnace may be producing to much water
Your furnace is more than 90% efficient and extracting so much heat from the gas that it condenses instead of blowing out steam. This is good! Figure that for every dollar you spend on fuel, you are getting back 90+ cents back in heat. Compare that to the typical units that only get 70 - 80 cents back in heat.
Yes you should drain your condensate to a proper drain via gravity or a condensation pump. I would recommend you treat the condensate first with a acid neutralizer prior to draining in municipal drains due to it's high content of sulfuric acid. You can purchase these filter type neutralizers on the net or at a good heating wholesaler.
SOURCE: Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
SOURCE: water puddling under the frigerator
one thing you should check first is to make sure the condenser fan is running. the fan is usually next to the drip pan at the back of the unit. make sur your condenser is clean and that air movement isn't blocked due to a dirty or clogged condenser which result in very little hot air is circulating around the drip pan to evaporate the water. if you have an icemaker and water dispenser check to see that theconnections located very close to the drip pan. other than that i don't know of anything else that could make(or leave ) that much water in the drip pan
SOURCE: water leaking from coil pan that is cracked down center
maybe you can fill the pan a little with some type of sealent, like resin, that might seal the crack pan..
