Question about Maytag MZD2666K Side by Side Refrigerator
ITEMS IN THE REFRIGERATOR ARE FREEZING INCLUDING THE WATER FILTER... SETTING HAS BEEN TURNED ALL THE WAY DOWN AND ITEMS STILL ARE FREEZING.
  • 42 Answers
It may be 2 parts damper control pn#67006249 or control board pn# 12868513
Posted on Aug 02, 2009
Frozen filter
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not opperating properly.
Feb 17, 2014 | Amcor Dehumidifiers
Filter frozen
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not operating properly.
FGHB2844LF water dispenser not working
Turn the temp down on the refrigerator side but not below freezing. Some frigs have a "trap" set up for the water dispenser. its located behind a panel in the frig and it is there to help chill the water before it dispenses. if the frig setting is too cold then it can freeze the water .
Dec 08, 2013 | Frigidaire FGHB2844LF Gallery 27.8 Cu. Ft....
Refrigerator freezes water and cola drinks inside it
have the thermostat checked as it appears that it has stopped controlling the temperature you set to
Jun 16, 2013 | Haier Refrigerators
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
My refrigerator is freezing the items inside at all diffenerent temperature settings. What is the problem
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Aug 16, 2011 | Haier HRQ04GNBSS Compact Refrigerator
Our fridigaire is running extra cold(some items are freezing) on the icebox side & the automatic water despenser is not working.when we turn down the control from setting 3 to setting 2 or 1, we can...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 06, 2011 | Frigidaire Refrigerators
What is part number for water filter?
Hello there:
Water Filter
Item # 1017291
$35.75
Item # 1017291
img-descriptiontab-on.png Ice and water filter in front access grille for refrigerators made by Whirlpool, including some Kitchen Aid and Kenmore refrigerators. This is manufacturer part 4396508, and it replaces 4392857, WF-NL300, WF-L500 and 4396163. Replace every 6 to 12 months.
Related Items:
Jan 26, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Frigidaire Refrigerator FRS26H5ASB5 side-by-side
Hi, yes, your thermostat could be faulty, yes there should vent( damper), check controls on freezer side, controls amount of cold air going to ref. side, yes could be stuck by ice, yes both adjustment are necessary, check manual, some thermostat are very sensitive, you should adjust gradually, wait for about 40 minutes, before adjusting again. yes there's vent flap (damper) yes that could be your problem, normally they get stuck with ice, remove covers to locate it., you 're smart, you will see, damper, good luck.
Aug 12, 2009 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator is freezing food AND broken ice container part.
Just lower it one number at a time , wait 24 hrs each time you re set it until you reach the right temp. 34-40 deg.
Your filter light has not came on most likely because it has not had the time to. You do not need to replace your filter every six months. This is a safe guesstamate from the manufacture , it depends on water quality and use of water , some filters will go years and years , the filter indicator does not even know if the filter is bad.
When you notice water pressure slowing when dispensing from the door you know the filter needs replaced.
Hope this gets you out of that service fee. This should FIX IT!
If you have any questions let me know.
Phil
Apr 14, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Maytag MZD2666K Side by Side Refrigerator Logo
154 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
