Question about Jandy Ray Vac Pool Cleaner for Inground Concrete
Ray Vac circles deep end, left turns and stalls at drain occassio
Circles pool drain
3 Suggested Answers
SOURCE: Ray Vac moving slow, circles deep end, sticks on side of pool
I have the same problem and the best solution is to repair/replace the hydro timer kit. It has inner gears that are plastic and wear down and doesn't rotate through the cycle of water flo that changes it's direction. I'm in the process of exhaustive repair and I'm going to replace the hydro timer - (inside part only) and then see what happens. Moving the gears did change it's moving patterns tho.
Posted on Jun 06, 2009
  • 990 Answers
SOURCE: ray vac circles drain, miking left turns
Could be something as simple as the direction of your return jets in pool creating a current in pool or more likely a hole in hose or stuck back up valve. If you pull the whole unit and take it to your pool store they will usually check it out and fix it just for the price of the parts.
Posted on Aug 24, 2009
I have a jandy ray vac pool cleaner that just goes in circles in the deep end of the pool.
look at instruction manual there is a setting you probably have to set
Jun 01, 2014 | Pool & Spa
Ray Vac cleans only in deep end
Make sure that your automatic pool cleaner doesn't have an obstruction in the hose that might not immediately be visible. This could cause it to circulate in one end of the pool. Also, check the water pressure to ensure that it has enough force to travel the entire pool.
Jun 27, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
My cleaner doesnot come out of the deepend and circles toth left
These automatic pool cleaners are pretty easy to troubleshoot. Make sure that the finger screen and energy filter are not dirty. If clogged or obstructed, both of these can cause the cleaner to go in circles and stall. Make sure that the backup hydro-timer is not releasing most of the water out of the discharge hole. If it is, you will probably have to replace the defective jet gear assembly. Make sure that the transporter jet is not plugged and that the debris chamber and hose are not obstructed.
Jun 02, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Ray Vac Pool Cleaner for Inground Concrete: Our Ray vac worked well for years but now it tends...
If your automatic pool cleaner is going in circles, you might want to check your backup hydro-timer. If it is releasing most of the water out of the discharge hoke, you might need to replace the defective jet gear assembly. Also, make sure that the transporter jet is not plugged. Check your hose to make sure that there are not any obstructions that would prevent proper movement.
May 18, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Ray Vac Pool Cleaner for Inground Concrete: after cleaning out debris from my ray vac my jandy...
What model is it? Is it robotic (indepentdent of your pump and filter)? If it is attached to your pump system, it could be the cord getting tangled and causing the pool cleaner to move in circles. You might want to consider running it when you are available to watch it or getting a robotic cleaner that you can set to operate at certain times. You might just need to check the hose for defects that would cause it tangle.
May 17, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
RAY VAC GOES IN CIRCLES
Change the pusher hose, the pusher jet, and the pusher jet sleeve. These are the first things coming from the end of the unit toward the wall. If you replace all of these parts and it continue to circle, change the front wheel.
Aug 10, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Ray vac circles drain, miking left turns
Aug 02, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Same prob. ray vac circles bottom of deep end. tink2b3 suggested moving the gears? what does that mean?
Mabey the gears in the backup valve a small football in line about 18" from wall. Just pull it from the water if you have one that is about every one to two munites it should send a jet of water out the side of the backup valve for about ten or fifteen seconds. If it dosen't you need a new one . Quite often a more likliy problem is tight swivels your local pool store can ck these for you and the leingth of your hose should just make the far point of the pool so it streches the hose and pulls all the kinks and loops out. Your pool store can help you with much of this and they will check the whole unit if you bring it in to the store and will usually just charge for parts.
Jun 09, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
I have the problem of the circling Ray Vac. And I haven't seen any solutions here. What's wrong, and what do I have o do to fix it?
PRESSURE is King. After taking apart my entire Ray-Vac and hoses, nothing seemed to fix my circling problem. I finally performed a full cleaning of all my mechanicals, especially the paper filter. I noticed a significant improvement in my water pressure and my Ray-Vac starting running all over the pool again doing her job like she used to. So, the Ray-Vac is very sensitive to water/jet pressure. Check your filter system. You want the most pressure you can get of out jet where you connect the Ray-Vac. This completely solved my problem.
Jun 07, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Dec 19, 2008 | Jandy Ray Vac Pool Cleaner for Inground...
Jandy Ray Vac Pool Cleaner for Inground Concrete Logo
75 people viewed this question
Top Jandy Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Jandy Garden Expert? Answer questions, earn points and help others
