Question about Fender Hot Rod Deluxe Guitar Combo Amplifier
HRD Issues... My amp has developed a problem. When I turn up my reverb knob past 1.5, I get a high pitched squeal, it also seems to me that the sound of the amp is lacking in general. I've replaced all three 12ax7's with new sovteks and tried another set of 6l6's with no luck... Any input? Thanks...
  • picsnflixs Aug 03, 2009
    MGUEFFROY, For some reason this link won't work? Would you please check the addy.
    Thanks.
    Thanks so much!
    picsnflixs@yahoo.com
    President:
  • 1,138 Answers
Try this article first for some ideas. http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165.
Posted on Aug 03, 2009
  • Michial Gueffroy Aug 03, 2009
    I found that article in the Guitar Player online edition. I saved it to my Bookmarks and I checked the address just now and it is the same one as I posted. Unfortunately the new edition is out now and I'm not sure if there is a way to access back editions. If there is some way to email you the article I would be glad to.
No reverb on my fender ps 160 Vocal amplifier
Here is a link to the schematic drawing
http://www.prowessamplifiers.com/schematics/fender/ps160.pdf
items to check are
1-the footswitch and plug
2-the reverb unit ,usually found at the bottom of the box
3-the reverb unit is plugged in to the amp
4-V6 a 7025 valve
5- the reverb switch is in the on position
Hope this helps
Len
Oct 14, 2014 | Music
I have a peavy classic 100 2x12 1975 has a high pitch squeal coming out of amp when powered on
If this happens only when the guitar is plugged in, most likely there are two possibilities. The first, you have some issues with the electronics in the guitar OR are using an acoustic guitar witch has an extremely sensitive pickup that provides nothing but feedback. If this is happening with the guitar unplugged, there is a mountain of possibilities.
Sep 01, 2014 | Music
When using my peavey mixer XR212 in a live musical duo over the past 8 weeks of using it bought new we are getting a loud high pitched hissing sound when we sing loudly.We assume this may be the reverb...
Hi, most times when you use a mixer for too long and don't service it or take it to be serviced,itmight one day develop a fault by it self..
If i may ask,when have you taking it for servicing? If never,please do..
Sometimes dust entering into a mixer can make it malfunction.....
Since you know how to use the mixer properly,you don't have problem with that ok, Just take itto a repair man for servicing and he might tell you if something else is wrong with it after servicing it..
Take care..
May 05, 2011 | Peavey XR 1212 Powered Mixer Mixer Powered
How to set a sustainer in zoom g1xn?
There is not a sustainer as such - However you can use the Decay parameter in the reverb module.
  1. Set the Module Selector knob to Reverb
  2. Choose a reverb type from H = hall, r = Room, s= Spring, A = Arena, t = tiled Room (arena 1 - should do it quite well)
  3. Turn the module knob to decay And rotate the value knob until the number 30 shows
Apart from that you may get a bit more sustain from using different Drive modules - the distortion drives such as Ed will give a longer sustain than the clean accoustic drive sounds.
Using heavier gauge strings on your guitar will also give longer sustain but make it a harder to play fast.
Feb 21, 2011 | Zoom Samson Technology Zoom G1XN Multi...
Reverb problem
I highly doubt the reverb pan is dead, there are TL072 opamps on the input and output of the Reverb pan. Check those out. You can get the schematic from fenders website here. U6A and U6B are what you are looking for.
http://www.fender.com/support/amp_schematics/pdfs/Roc_Pro_1000_Schematic_B12.pdf
Dec 26, 2009 | Music
Marshall VS65R is powered up it hums
Blown speaker NO (would not get sound at all)
Bad Reverb UNLIKELY (controls would deselect reverb and it would be out of circuit)
Bad preamp tube NO (controls have no effect)
Bad rectifier and/or filter caps LIKELY
Bad power amp POSSIBLE
Nov 29, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
Aug 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Fender Hot Rod Deluxe Guitar Combo Amplifier  Logo
407 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
