Question about GE JVM1630 Microwave Oven
I have a GE Jvm1631WB microwave and it runs normally but it doesn't heat up...what do I do?
Microwave will not heat during operation
Posted on Oct 17, 2009
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My ge spacemaker jvm1631wb 001
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
[0-[0-[0-[0-[0-[0-[0-[0-[0-[0-[0-[0-[0-
Posted on Feb 22, 2011
GE profile JE2160SF03 microwave oven doesn't heat
3 things high heat low heat cencor or magnatron is bad
Apr 02, 2013 | Microwave Ovens
Microwave runs but doesn't heat. Can we replace the heating element ourselves?
There are no heating elements in a normal Microwave Oven: instead, an extremely dangerous High Voltage and Amperage Magnetron is used and its replacement is not considered safe for the average handyman!
Check if your unit is still under warranty and if so, take it to an approved warranty appliance repairer as directered by the manufacturer or supplier.
In any case, nowdays, the high cost of a replacement Magnetron (if you can find one) is usually more than the cost of a new equivalent Microwave oven.
Hope it helps!
May 15, 2011 | GE Microwave Ovens
Our GE Spacemaker XL Microwave Oven Model JVM1631WB 002 isn't working properly. It comes on, lights up, turntable works but does not heat food. It also sounds very different (loud) when on.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 04, 2011 | GE JVM1631 Microwave Oven
My ge spacemaker jvm1631wb 001 microwave is not heating?
Basic
heatman101
Nov 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have an 11 year old jvm1631wb. is it possible that the fuse is bad even though the light comes on inside? ther is no display either
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Yes..
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Model # JVM1631WB makes an awful sound when cooking, and the turntable does not rotate. The sound is not normal, and may be related to the turntable not working?
Yes! On many GE models (yours included) the internal cooling fan has a built-in tap (like a transformer) that powers the turntable motor, and in some cases, the stirrer motor, too.
If the internal cooling fan does not run, the magnetron can overheat in about two minutes and overheating too much will destroy it.
If the stirrer is not running, arcing will occur which will damage the stirrer and eventually the magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
The oven should not be used - and should stay unplugged - until it is repaired.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1640WB007 MICROWAVE RUNS BUT DOESN'T HEAT. WHAT COULD BE THE PROBLEM?
It is most common for the magnetron in GE microwaves to go out. This is the part that heats the food. Basically everything on the unit works and runs like normal but it wont heat. Check your owners manual for the warranty on the magnetron. They usually put a 5-7 year warranty on the part itself. If you dont have the owners manual check for it online. Hope this helps you.
Jan 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No heat
If the fan, lites, all work and appears to be running normal but just no heat, chances are its the magnetron that has failed. Sometimes magnetron will make a deeper noise if it has failed
Nov 25, 2009 | GE Profile Spacemaker Over-the-Range...
GE JVM1630 Microwave Oven Logo
2,100 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
