Question about Asko W6221 Front Load Washer
Asko w6221 washer won't start
I have an Asko W6221 washer that I purchased in 2002. Recently, it stopped working (only the power light comes on). After doing a little research, I thought the issue was the door switch. After I ordered a new one and replaced it (what an ordeal that was when you don't have a diagram to work from!), I was able to start the machine and begin a run. However, it never finshed the run (it stopped when it was supposed to drain) and I can't get it to do anything anymore (not even a manual rise, spin or drain). Do you think I have an issue with the main board? Asko includes a high-level block diagram of the machine inside, but it doesn't provide enough detail to troubleshoot this issue. Do I take another gamble and replace the board (it costs $350)?
  • 725 Answers
First I would check you drain pump ... make sure it is clear and clean.. next if you have a meter be sure it is getting power and that it is not shorted ...if it is not getting power then I would check the wires first then check your control.
Hope it helps if Not let me know more about you problem..I can help
Posted on Sep 26, 2009
Ciruit board asko w6221 washer
Not normally. Most manufacturers supply boards complete and ready to go in to replace a dud. Unless you know an electronics whiz who can identify what component(s) have failed, you are probably better off and reliability wise, to get a replacement board.
Sep 28, 2014 | Asko W6221 Front Load Washer
Asco W6221 won't drain. Sounds like the signal is being sent, but won't continue the process. I've cleaned out the drain pump and that seems to be working;as best I can tell(took cap off, water on the...
CHECK UR WATER PUMP PROPELLER FOR OBSTRUCTION, CAN U TURN THE PROPELLER BY HAND? CHECK FOR BLOCKED HOSES, IF PUMP IS ELECTRICAL TYPE THEN CHECK WITH A METER
Dec 17, 2013 | Asko W6221 Front Load Washer
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
Asko w6221 Washer just spins back and forth for hours in wash cycle. It fills with water, then simply rotates back and forth...it will do this for a well over an hour. I have to manually select the rinse...
This seems to be a fault with the controller unit as there is no program cycle execution . So remore the power plug and let the processor reset, now try with different programs and if the cycle does not move it is possible that the controller unit is faulty.
Sep 21, 2011 | Asko W6221 Front Load Washer
My washer w6221 won't drain
Check this following things then your washer will be fine.
* Has the drain hose been put flat on the floor?
* Is the drain hose clogged with lint?
* Is the drain hose kinked?
* Is any part of the drain hose higher than 20 cms from the floor level?
* Is the extension drain hose longer than 3 m?
* Is a narrow drain hose being used?
Thanks for your question.
Jun 26, 2011 | Asko W6221 Front Load Washer
I have an Asko front load washer W6221. I have
I had identical problem. I diagnosed it to be the motor brushes on the front of the motor. They have an off switch in them when they get worn out. Easy to check and replace. Remove front lower panel (two torx 20 screws). Brushes are visible and are held with two screws each. One on each side of motor. Remove two screws on each brush and unattach wire. Two new motor brushes were around $75. Literally tooke 30 minutes to replace. Hope this is your issue!
Oct 14, 2009 | Asko W6221 Front Load Washer
To little water?????
I DID SEARCH ALL OVER AND THIS THE MANUAL I FOUND FOR YOU :) HOP IT WILL HELP ...
http://194.14.129.136/brandsite/DocumentOpen.aspx?did=3878&mid=43&lid=2
Sep 22, 2009 | Asko W6221 Front Load Washer
Asko w6221 washer
Try to replace the motor brushes. This is the most usual problem on these machines.
Good Luck
Nov 21, 2007 | Asko W6221 Front Load Washer
W 6221 power indicator light is out
take off the top it could be a bulb gone
Oct 02, 2007 | Asko W6221 Front Load Washer
Asko W6221 Front Load Washer Logo
375 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
