Question about Panasonic PT-AX100U-EC DLP Projector
The light goes out after 4 minutes and can only be restarted by turning off the unit and turning it on again. At first this single reset was enough, now it takes two times before it runs the rest of the day perfectly. I changed the bulb and reset the hours yesterday, but it still does it. Any suggestions?
    Problem Solver:
  • 8 Answers
Please see this link for your free and easy solution:
http://www.fixya.com/support/t451897-panasonic_pt_ax100u_ec
Posted on Oct 17, 2009
I have a 4 year old Bosch Ecologixx 7 self cleaning condenser dryer, WTW86561GB/02. The problem is after 10 minutes the machine just switches off, and the display panel goes dark
sounds like the thermal safety overload is cutting the power due to overheating hence why it just turns back on after a certain time, when the safety overload reaches a certain temperature it will cut the power to the machine or in some cases just the heating elements, once it cools down it resets and power is restored and by using the warm setting it obviously isn't as hot so its not overheating, its highly likely it is all blocked up internally with lint (i know it says self cleaning but they never work for more than a few years before requiring a proper clean and service)
Jan 30, 2017 | Bosch Washing Machines
Blinkin light
Turn the main power to the unit off, leave off for about 20 seconds then turn back on. Unit should restart. The blinking light is a fault light that can be reset by turning main power off. Most times it will restart no problems but if the fault re occurs there is a problem with the unit itself. If the fan starts and runs for around 4 minutes on cooling mode then stops and blinks there is a problem with the outdoor unit.
Mar 31, 2014 | Daikin Mini Split Ceiling Suspended Units
Overhead light will not come on when door is opened
Press and hold the Lock button until the light blinks (about 10 seconds). A single blink indicates that the timer is reset to 1 1/2 minutes. Repeat the procedure and the light will blink twice, resetting the time to 2 1/2 minutes. Repeat again for a 3 1/2 minute interval, etc. up to a maximum of four blinks and 4 1/2 minutes.
Dec 02, 2011 | Craftsman Sears Liftmaster Garage Door...
My commercial cool air conditioner goes off after 5 min. The stop light is flashing? I can't get it to go on?
It's going thru the defrost cycle. Once that ends, the unit should restart. If it doesn't wait until 3 minutes have elapsed, after the stop light goes out and restart the unit. If that fails, turn the Master ON/OFF Switch to OFF & unplug the unit. Wait 15 minutes, plug the unit back in and turn the Master ON/OFF Switch to ON. The unit should have reverted back to the original factory settings. If so, reset the controls as you like.
I hope this helped you and thanks for choosing FixYa.
Jul 24, 2011 | Haier CPN14XC9 Air Conditioner
How do you set the light delay, I lost my instruction booklet.
The 4½ minute interval can be changed to 1½, 2½ or 3½ minutes as follows: Press and hold the Lock button until the light blinks (about 10 seconds). A single blink indicates the the time is reset to 1½ minutes. Repeat the procedure and the light will blink twice, resetting the timer to 2½ minutes. Repeat again for a 3½ minute interval, etc., up to a maximum of 4 blinks and 4½ minutes.
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
When our garage door opens, my light turns off immediately. How do I get it to stay on for about 5 minutes?
Try this:
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
The light stays on for a long time although it shuts off (a lot more that 4.5 minutes). Can this be adjusted to be shortened? Where and how on the unit?
If you have one of the newer models the duration can be changed by holding in the lock button until the light blinks (about 10 seconds.) A single blink indicates that the timer is reset to 1½ minutes. Repeat the procedure and the light will blink twice, resetting the timer to 2½ minutes. Repeat again for a 3½ minute interval, etc. up to a maximum of four blinks and 4½ minutes.
If your opener has the motion sensor feature and a person enters the garage and walks in front of the door control the light will come on for 5 minutes and then shut off.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
DN- S3500 Cd stuck
HI,
Please reset the unit for 4 hours by unplugging all the cords,even the power cord from the unit and then plug them back again after 4 hours.Now try ejecting the disc.Let me know the result.
Feb 10, 2009 | Denon DN-S3500
When turned on, lights come on, but will not blow...
First off, I dont think you caused this problem by vacuuming the unit. It is possible that you did not leave much time before restarts but you then said you tried leaving it off for 5 minutes which should be adequate enough. f you let the unit set for a couple of hours before a restart that should be enough time for the compressor to cool down to ambient temp. I would then try restarting the unit, if it works leave it on for a while and make sure it is producing enough cooling. If there is no change in the situation I would suggest that it would need to come back out of the housing and check that the compressor is receiving voltage to it. It is possible a start capacitor or relay is the cause of the problem. If it started first time I would suggest it is worth having it checked by a professional as it could be the charge or the starting devices. First off though let it completely cool down and try again. Hope this is of some help.
Sep 14, 2007 | Heating & Cooling
Panasonic PT-AX100U-EC DLP Projector Logo
274 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
