Question about Hoover HCA390FFK Bottom Freezer Refrigerator
Hoover HCA390FFK not draining through drain plug
Hoover HCA390FFK freezer compartment not draining defrosted water through drain plug, hence water builds up and refreezes
    New Friend:
  • 63 Answers
A common problem is a blocked drain tube. Using compressed air, blow through the tube to clear it. Also, make sure that th refrigerator is level in both directions to allow proper pitch for draining.
Posted on Aug 02, 2009
Water in the bottom of the fridge
In the freezer compartment, there is a drain. This drain gets plugged up. When the freezer defrosts the evaporator the water from it runs down to that drain. If that drain is plugged up, the water from the defrost can't drain out. The water will collect under on the bottom and then freez when the freezer starts up again. Take out the bottom drawers and us a hair drier to melt the and unplug the drain.
If that doesn't work, let me know.
Sep 24, 2014 | Refrigerators
Excess water dripping into refrigerator from freezer. I am in the process of defrosting. Ice build up behind freezer back wall. Do I need a new heater or will clearing the ice from drains suffice?
Clearing the ice build up is a good start,the problem though is the drain pan under the coil in the freezer thats iced up is blocked so when the defrost heater comes on and melts the frost from that coil,it the water is collecting in the freezer and in many cases drips into the fresh food compartment,clearing the drain will resolve your leaking/ice build up issue.THE DEFROST HEATER IS GOOD melting the frost in the first place and hence forth that melted frost stays in the freezer and becomec ice.
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
Magic chef frost free refrigerator leaking water down the rear appears to be coming from the freezer compartment water puddles under veg. bin and then out onto the floor do not see a drain hole in...
Generally you have to remove the back panel of the freezer. There you will find the freezer coil and fan. the defrost water drips off the coil during defrost and gravity flows down thru the drain. Hole should be in center of unit. Those drains plug up. clear drain.and make sure panels go back on correctly
Jun 25, 2011 | Refrigerators
Hoover a class, fridge freezer, fridge keeps icing up and is supposed to be frost free
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 21, 2010 | Hoover HCA390FFK Bottom Freezer...
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Feb 04, 2010 | Refrigerators
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Whirlpool fridge getting water from upper freezer compartment
well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Oct 12, 2008 | Whirlpool Refrigerators
Bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Jul 27, 2008 | Bosch Refrigerators
Hoover HCA390FFK Bottom Freezer Refrigerator Logo
374 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
tom wright
tom wright
Jim Goldsmith
Jim Goldsmith
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
