SOURCE: Grass clippings won't go into bag
Hello steveacosta:
Check the Blade. If the Lift Area Behind the Sharpened Area of the Blade is Worn, then you will have the Problem you Described.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: oil for yardman lawn mower
Only 30wt DETERGENT HIGH QUALITY oil, never use NON detergent or 10-40. Takes approx. 20 ounces to fill
SOURCE: rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
SOURCE: lawn mower cranck but wont start...
Since you already checked for spark and air I would drain all the fuel out of it and check that fuel for water. Over time some lawn mowers end up with contaminated fuel. You can see the water sitting on the bottom of the fuel if you let it stand for a bit in a small plastic bowl.
Be sure to empty and dry out you fuel can as well. Especially if the mower stopped running right after a refuel. Which is a good sign your gas can is contaminated too.
