Question about Air Tools & Compressors
Slow to impossible to reach 150 lbs.
I have investigated this problem and it is a constant leak from an inline brass component that appears to be some sort of pressure relief valve for when the compressor shuts off. The main pressure relief valve does not leak at all except when I pull on the ring attached to it.
  • fredericksim May 11, 2010
    Where is the leak , at the pressure switch or at a brass valve in the tank . I need a little more info to help solve this problem.
  • 3,600 Answers
The back pressure valve may have some carbon build up o it, or the spring may be weak pull it apart and lightly sand the disk rinse with gas and lightly oil and reinstall.
Posted on Aug 06, 2009
Need torque specs for front wheel bearing on 2004 dodge 3500 dually
The hub bearing retaining bolts are 150 ft. lbs the center axle nut primary torque 135 ft.lbs rotate 5-10 times increasing torque by 50 ft.lbs until final torque of 265 ft.lbs is reached
Mar 23, 2014 | 2004 Dodge Ram 3500 Truck
Builds up pressure then idle and leak air out is there a shut off that hold air at 180 lbs.
You did not mention a brand or model number, however, most air compressors have a check valve (brass nut) at the tank that retains the air in the tank. If check valve is leaking, air will leak back thru the checkvalve into the pump or the unloader. You must have a two stage pump if you are holding at 180psi. If, however you have a single stage pump (that should be set about 150 or less) you are overloading the system. Good luck
Nov 09, 2012 | Air Tools & Compressors
Compressor runs but the air bleeds out think it might be stuck reed
If your compressor reaches the cut-out pressure (or very close) , most likely not reed valves. Usually air leaking when compressor is shut off is result of leaking check valve at the tank. Look for brass valve and remove. Somtimes the valve is repairable if debris is keeping valve open. Clean or replace as needed.
Oct 21, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Air compressor leaking air
you have a bad check valve ,the little brass valve is working normal
Apr 18, 2010 | Clarke Power Products AC2002A 2 Hp Air...
The engine on my 1988 f- 150 idles up n down
Assuming that you have no vacuum leaks, the situation is normal. Over the years the mmission components of your engine wear. This causes an uneven air fuel mixture which causes the emmission controls to constantly try to compensate for the rich/lean mixture. Thank you, Dana
Mar 30, 2010 | 1988 Ford F 150
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
Drops compressiom from 120-60 psi after 3 new pressure switches
When the pressure switch fails the comperssor will overpressure to the point of safety release at about 150 - 160 psi. It sounds as if your compressor is not producing enough pressure to cycle off at 120 and just keeps running. This happens when air is leaking from fittings or worn cylinder / reed valves. Don't worry, with some simple tests we will find the actual problem. I am assuming that your compressor is oilfree type. If there are leaks the compressor may not reach set pressure. I use soapy water on all connections and on the head/headvalve (remove plastic covers to get to all parts that may leak) while compressor is running. Make repairs as necessary. If still low pressure, while compressor is running and has reached max obtainable pressure (in your case 60 lbs), carefully place finger over intake port hole (remove filter). If the compressor is pumping normally but leaking there will be ample suction at intake and cause the compressor to speed-up when intake is obstructed with finger. If you feel plenty of suction and no visible (soapy water) leaks, then the problem is probably the cylinder /ring is not correctly seating /scratched and air is leaking past cylinder. Make sure that the cylinder /piston ring is properly aligned and that the lip on the vinyl ring is up toward the head. On oilfree compressors you can examine the cylinder by pushing the piston all the way up, then look for scratches neer top of cylinder. If scratched, pressure is leaking past cylinder, install cylinder kit. If you do not feel suction but rather air blowing out of the intake, (do this test when tank has reached 60 psi) then the problem is the headvalve plate/reed valves are leaking. The reeds must seal perfectly on their seats and not be bent or have obstruction. Replace as necessary. If reeds or headgasket is leaking the discharge air will be very hot. Only one other thing to check and that is the intank check valve. Easy to check. Run compressor till you have about 50+ lbs in the tank then unplug compressor. Carefully loosen the inlet hose at checkvalve and listen for air leaking out of tank. (check valve is the brass valve at tank) If leaking replace checkvalve. Use caution when removing head to try and save the gaskets. If you have oil type pump, and no air leaks (soapy water test) suspect reed valves/valve plate. Good luck on your repair and email if you have other question.
May 06, 2009 | Campbell Hausfeld 28 - Gallon Air...
Head gasket torque specs
Here you go, I hope this is what you were looking for:
For 1987-94 models, the cylinder head bolts are tightened in 3 progressive steps. Tighten them in the proper sequence as follows:
Step 1: 50-55 ft. lbs. (68-75 Nm) Step 2: 60-65 ft. lbs. (81-88 Nm) Step 3: 70-85 ft. lbs. (95-115 Nm) Let me know if I can assist you with anything else.
Apr 30, 2009 | Ford F-150 Cars & Trucks
Makita MAC2200 runs fine (with new Manifold Switch and repaired power cord) but there is an air leak under the new manifold switch that seems to be a feature of the switch. When set to automatic, the...
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Mar 18, 2009 | Makita Air Tools & Compressors
Air Tools & Compressors Logo
77 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
