Question about Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground
We have a Hayward above ground heater for our pool. It ran for two days properly and we shut off because it was warm enough. We tried to turn the heater on again, but it won't stay running. It runs heat for about ten seconds and shuts off. Can you help us with this problem?
    Champion:
  • 246 Answers
You may not have good flow of water clean the filter first
Posted on Aug 19, 2009
  • 640 Answers
Here is a copy of the users guide for these pool heaters. If you consult the troubleshooting guide, you should be able to walk through, step by step, what could be wrong with your pool heater.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Posted on Dec 07, 2010
Pipe boosted are anyone get the same troub
all the warranties are based on the PROPER MAINTENANCE OF WATER CHEMISTRY. if you cannot prove that the water was balanced properly, you will not have a good time passing this through warranty. a severely unbalanced pool can experience this type of failure very quickly.
Aug 18, 2014 | Hayward 100,000 BTU Pool Heater H100ID1 -...
How do I adjust the pressure switch on my hayward h250 heater
The purpose of the pressure switch is to verify the pool pump is operating properly and water pressure is present in the heating chamber. When water pressure is not present, the heater control system is designed to not allow initiation of flame. The pressure switch is preset at the factory for deck level installations. When the heater is located below the level of the spa or pool, the pressure switch may require an adjustment to compensate for the no-flow static head.
CAUTION: The Hayward Pool Heater is essentially a furnace. A trained technician should be consulted to repair it. DO NOT OPERATE the Hayward Pool Heater without a properly functioning and calibrated water pressure switch. The pressure switch adjustment requires both the pool pump and the heater be operational. As a result, extreme caution should be used during this procedure since sources of energy can not be isolated during the procedure.
The following procedure is recommended to calibrate the pressure switch.
1. The water pressure switch is located behind the front service panel. The pressure switch is typically on the left side, above the burners.
2. Be sure the water filter is clean before making the adjustment.
3. With the pump and heater system switch on, carefully turn the pressure switch adjustment dial clockwise, until a click is heard from the gas valve.
4. Turn the adjustment dial counterclockwise 1/4 turn.
5. Turn the pump off and on several times. The heater should shut off immediately when the pump is shut off. If the heater fails to shut down when the pump is off, repeat the steps above until the pressure switch is properly adjusted.
6. If the adjustment process fails to produce proper results the pressure switch should be replaced.
Jun 22, 2014 | Hayward H Series Pool & Spa Heater...
Hayward hd100id blower works water luke warm
It sounds like the thermostat is turning the heater off before it gets the water to temperature. It is probably the sensor, as that is the most common cause, but may be otherwise.
Nov 28, 2013 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I have a hayward pool pump. I ran the back wash
It sounds like the start switch contacts are not making good contact or there also may be a weak capacitor. These possible solutions do require a basic knowledge of motors to remedy. Start contacts can be cleaned and adjusted until proper replacement can be done.
Aug 16, 2009 | Hayward Pool Products Economy 1 Hp Above...
Pool heater will not ignite
check pressure switch,if it is faulty or out of adjustment it wont allow it to go tomain burner
Jun 17, 2009 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Open Questions:
Hayward 100,000 BTU Pool Heater H100ID1  - Above Ground Logo
422 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
