The knee lever just pushes in to install, so it is logical that it should just pull out. You may need to apply some muscle and wiggle it at the same time. Possibly apply some heat from a handheld hairdryer. My last option would be spraying a little silicone spray into it.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwi7oN3IiancAhUlzIMKHYL9BxwQFggoMAA&url=https%3A%2F%2Fwww.juki.co.jp%2Fhousehold_en%2Fpism%2Fimg%2Ftl2010q%2Fdownload%2FInst_2010Qi.pdf&usg=AOvVaw1Pfw4EcDyH9jENSZ_9lB2z
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
SOURCE: i have a juki sewing machine and the nittle
the problem of your juki sewing machine is your bobbin. adjust your bobbin to the right place.
SOURCE: have a trouble wiht the computer on mi juki sewing
you can go to the store of juki sewing machine,
contact a juki dealer & ask them about the lever
