Question about Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Trimmer Runs with choke at idle, then stalls
If I keep the choke open, I can go full throttle. Without the choke held open, any throttle movement causes it to stall.
    Novelist:
  • 168 Answers
Sounds like somewhere you have a air leak. Most likely it's somewhere near the carburetor intake or maybe the carb itself. Could be a line from the primer if it has one and i do believe it should that could be leaking or loose. Good luck.
Posted on Aug 02, 2009
Weed wackier gas trimmer
didnt specify the make and model so generic answer ---check fuel mixture is correct --check the filter in tank is not plugging up--look for damaged / crack in fuel feed lines-look at spark plug --carb may need cleaning --exhaust port may need cleaning
Jul 04, 2016 | Garden
I push primer on craftsman 32cc weed wacker trimmer and gas just runs out carb all lines are hooked up properly any suggestions
its supposed to,thats where the gas goes when you prime it,hold it up or choke it to start
Apr 17, 2015 | Craftsman Garden
Craftsman 32cc gas trimmer won't start.
Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
I have a Craftsman 32cc weed trimmer, can't give gas, it stalls
Usually the diaphram is wore out. It is a relatively inexpensive part. Does it run better with a little choke? If the answer is yes chances are it's the diaphram. Also sometimes the adjustment screws can move. There are two, one for low speed, and one for high. With the engine warmed up make small movements on the screws (some are marked low, and high) in, and out adjust til the engine runs at its optimum.
Hope this helps!
May 04, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman blower stalls when choke is disengaged
You need to play with the timing adjustment, either on the spark plug, or the gap between the contact and the magneto.
That'll do it ;)
Don't forget to rate, thanks
Jul 31, 2009 | Craftsman 4 Cycle Blower/Vac
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Craftsman 25cc Gas Line Trimmer Logo
1,532 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
