Question about Whirlpool Calypso GVW9959K Top Load Washer
THE CODE LD IS SHOWING UP AND WASHER IS NOT OPERATING
    President:
  • 1,273 Answers
Press stop, cancel twice to reset. The Ld error is when it takes longer than 5 minutes for the washer to drain and reset the sensor. You probably have a partially plugged strainer or drain line. To check the strainer, remove the kick panel at the front bottom of the machine. The strainer is ibetween the drum and the pump, being connected to the drum with a rubber hose. Open the strainer (caution, water!), and clean. If you did not find much in the strainer, clean the drain hose. Dump the contents of the drain hose into a bucket. If possible, run an empty losd with dth drain line pointed outside.
This should fix your issue!
Best regards, --W/D-- feel free to rate this solution...thanx!
Posted on Aug 02, 2009
  • 16 Answers
SOURCE: ld code wont turn on
Well the generic answer for an LD code is Long Drain, chances are the Pump is clogged. if this is a Calypso, it can be fixed by tipping the unit back and unscrewing the three 5/16 screws in the bottom/front of the bottom panel. this will give yuou access to the pump. its on the right. there are 2 styles of pump, the older style is a large plastic piece that has 2 clips holding it on. this is next to impossible to clean out. if its lint of loose fabric that has gotten in, you wont be able to remove it. if its a sock, thats a lot easier. you will need a new pump if you cant clean it out. if its the newer style pump, these are made to be able to clean them easily. 4 torx head screws to remove the pump chamber housing, de-lint it and button it back up. on both pumps your going to have to deal with a lot of water ejecting. if you have hose clamps use those and put down lots of towels or a strategicly placed bucket. leaning the tub back as far as possible can help to, but not all the way, it could spill out the top of the tub then. best thing to do is to bring it outside where a spill doesnt matter. good luck.
Posted on Nov 25, 2009
jimappliance
  • 42 Answers
SOURCE: the code LD is showing
ld it a long drain check drain pump
SOURCE: yes, my cabrio washer will not drain and it had
did anyone give you an answer to this problem, i am having the same thing happen to me
Posted on Oct 05, 2009
  • 171 Answers
SOURCE: my washer is showing the
LD stands for long drain.  unit has decided it is taking too ling to drain the water out.  check the drain hose for any obstructions.  if you feel capable, you can also take off the water pump and do the same.  may also be a bad water pump.
Posted on Jul 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: What does it mean when LD shows in the display on my washer?
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
'Ld" sign is showing in
Hello.
What this code means indicate that the door of your washer is not well close .
L= LOCK
D=DOOR
So what you need to do to solve the problem is to open the door of the washer then close it properly.
Good luck.
Thanks for using fixya
Sep 06, 2011 | Washing Machines
My washer is showing :LD"
Sounds like the strainer/filter is partially blocked causing Long Drain, remove the access panel and unscrew filter cap to clean, hopefully nothing is jammed in the pump.Hope this helps
Jan 20, 2011 | Washing Machines
My whirlpool cabrio he 4.5 cu ft washer keeps throwing the LD code what do I do?
Error Code - Ld Problem - Long Drain Solution - When the machine consumes 5 minutes or more to drain out water to where the operating pressure switch resets
Sep 02, 2010 | Washing Machines
What does error code LD mean?
"Ld" Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. please remember to rank how this opinion has helped in your appliance situation and if you have any more questions please message me back thank you again and have a nice day
rickead1
Aug 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer is showing the "ld" code ,how do i fix it?
Jul 28, 2010 | Kenmore Oasis HE 27062 Top Load Washer
My washing machine is a Maytag Bravo, My Manual is packed as were moving, I need to know what the error code LD is and how to clear it
Error code LD means Long Drain. It flashes when washer takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Make a careful visual inspection of the hoses, and see if you notice anything under the main tub, that could be causing a blockage.
Jun 18, 2010 | Maytag Bravos MTW6600T Top Load Washer
Ld code on my whirlpool cabrio, won't drain water, what do you do?
Hi There
OK here's something you can read to help you with. I hope this helps.
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Yes, my cabrio washer will not drain and it had the code Ld showing, any help??
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
The code LD is showing
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
254 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
