*** You should check your warranty and call for service as there are HIGH voltages in a dryer that can Kill. ***
*** The following is for information only ***
* Disconnect dryer from power outlet (it's the really big plug)
* how to check dryer (detailed); https://www.youtube.com/watch?v=fv2UqRUKnm0
* Lots of things can cause the dryer not heating:
* Check power at dryer outlet (220 or 240 Volts AC)
* Check High limits (thermal fuse). Check and replace.
* Check the heater element for continuity.
* Check timer.
* Digital driers have a CPU controller and may have a hardware problem and/or bad programing. This may be caused by a surge or lighting strike. Either way, you will need a MFR qualified tech to check as these newer units are all digital. Some (if you have the wireless option) can be checked by calling the MFR help line. They can check it by internet remote link.
* Older dryers with a selector switch (the knob) gets used and abused. Check rotary switch (they burn out all the time as it has the heater and motor load on the same contact) If it's burnt then change it as it may cause a fire.)
* Look for signs of burning; wires, melted parts, missing or loose parts especially electrical connections.
* vacuum out lint and check all spade (push on connectors) for rusty or burnt connections (caused by high amperage loading from motor and heater load.)
* Final; Again, be safe and call for service. Many of these washer and dryers come with very long warranty (5-10 years) Why fool around with something that is already covered?
Aloha, ukeboy57
