Question about Toshiba Satellite M35X-S349 Notebook
Computer crashes when turn on Wireless switch
After I turned the Wireless switch off on my laptop it crashes everytime I try to turn it back on. Toshiba Satellite M35x s349
  • 27 Answers
Problem:sounds like polarity is switched on wireless card
Solution: remove cover plate on bottom and make sure black wire runs to Main and white wire runs to AUX
Posted on Aug 02, 2009
My luxor tv keeps crashing and turning off every time i try to connect wireless
The dongle is not compatible with the TV. Check the owner's manual for compatible models.
Apr 07, 2014 | Luxor 19822 COB
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
I don't see any WiFi connections in my computer (Windows 7) and WiFi indicator infront of laptop does not lit. Troubleshoot shows "Wireless capability is turned off". The switch in front of PC is turned on...
First, turn the wireless switch OFF and switch it back ON
(make sure sure that there is a BLUE light on the wireless indicator)
then press Fn+F5 (this will ENABLE the wireless capability of your computer)
>Try to detect wireless networks
>comments suggestions ratings and violent reactions will greatly be appreciated
Sep 23, 2010 | Computers & Internet
EVERYTIME I TRY TO TURN MY WIRELESS ASSISTANT ON, MY COMPUTER FREEZES. EVERYTIME I TRY TO LOAD MY INTERNET EXPLORER, MY YAHOO PAGE WON'T LOAD WHAT CAN I DO?
Make sure Wireless Zero Config is running.
Try to uninstall the wireless assitant software that came with the laptop (NOT THE WIRELESS CARD DRIVERS!!) and use the built in windows wireless assistant. (Usuelly does the job untill you deside someday to format your computer.)
Apr 21, 2010 | HP G60-230US Notebook
Computer crashes
A few things can cause this.
  • Shorted wireless card
  • Weak power plug/connection
  • Weak regulator (inside the computer)
  • Hardware driver issues. You should get a blue screen
Having done a restore eliminates the bad driver really. So we should expect one of the others. If it is a weak power supply, connector it should shutdown when using the cd drive
Try another wireless card if possible.
Jan 24, 2010 | Gateway 4542GP Notebook Computer With...
Firefox crashes everytime I try to start it, last time it worked without an issue was Friday, October 23. When I turned on my computer the next morning, Firefox will not start. It crashes everytime.
hi this is john,
i always face this problem my dear so i follow these instruction which i m sending u that particular link which will help u alot..
http://support.mozilla.com/en-US/kb/Firefox+crashes
follow this link and get ur problem solved
regards
john
Oct 25, 2009 | Mozilla Firefox
My computer crashed, so I wiped it clean and started over. I down loaded the software but did not pull the card out first. Then I uninstalled the software, shut the computer down, removed the card, turned...
if your problem is your computer crashes due to wireless adapter card.. try turning off your pc and remove the card, then boot your pc.. and see if it still crashes
Oct 19, 2009 | Cnet CNWL-311 802.11b (CNWLC-311) Wireless...
Wireless adapter crashes Toshiba Satellite A55
Try to update the wireless driver, also update the firmware (BIOS). it will fix your problem, it is software conflict.
Thanks
Oct 04, 2009 | Toshiba Satellite A55-S1063 Notebook
Hi there:)
TRY THIS:
call in your provider to change the ssid and the network key
[all computers will be disconnected]
and then try to reconnect them one by one to the new ssid or network name
this should resolve the issue
always make sure that the wireless properties are okay and the same as the router
also check the device manager: network adapters if they are properly installed and no errors on the icon for the adapters. for windows OS[]
Dec 18, 2008 | Hawking (hfs5t-eu) Networking Switch
Toshiba Tecra A3-S611 Freezes
If by "turned off" you mean with the switch, the wireless adapter itself is probably bad.The cheapest solution is to buy an external wireless adapter.
Sep 10, 2008 | Computers & Internet
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
392 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
