My central air froze after we had a power outage. Now the outside conpressor is shutting down coming on.
  • 68 Answers
Sounds like a coincidence. the unit will freeze if low on freon and a low pressure switch in the unit out side will make in cycle off and on
Posted on Aug 03, 2009
Unit has no power, we had a power outage, power coming to unit is good.
Break A Breaker No Power To Air Conditioner Tripped AC ...
? 5:08
https://www.youtube.com/watch?v=nS2pBg2QbnM
Jun 2, 2013 - Uploaded by KungFuMaintenance
Break A Breaker No Power To Air Conditioner Tripped AC Can I Get A ... I have a GE model # AEM14aQL1 air conditioner wallunit 14,200 BTU ...
HVAC HELP! Unit has no power and Fan, Heat and AC are all ...
www.city-data.com > City-Data Forum > General Forums > House
Jul 1, 2012 - 10 posts - ‎8 authors
Now, when I attempt to turn on the AC I get no response from the unit. Nothing is blowing out of vents, even when fan mode is set to on. So far I ...
No power to outside AC unit - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 5, 2005 - I have an outside AC unit that appears to not get power. The circuit breaker is OK, and the fuse "appears" to be fine, but do not know if there is ... A/C problem, thermostat has no power
Aug 5, 2009
central a/c unit has no power
Sep 29, 2004
More results from www.doityourself.com
Dec 29, 2015 | Heating & Cooling
10 year old Goodman central AC won't come on after mini power outage. Breakers and wall thermostat OK.
Check the start capacitor for proper value and replace if necessary.
Ditto for thermostat. There are also some fuses in the air handler that might need replacement.
You may have had a power surge that had a bad effect on electronics of unit. Make sure that unit is receiving power for one thing. U might try to reset the electronics by completely shutting off all the breakers to compressor and air handler and waiting a few minutes and then reconnecting.
Sep 02, 2015 | Goodman Heating & Cooling
Central heating&cooling
sounds like your compressor is getting hot and shutting down have you washed your outside condenser coil? Could be dirty causeing high head pressure and shuts your compressor down. Try washing your condenser coil I think this will help you. If not you may be low on charge of Freon.
Aug 17, 2014 | Rheem 13AJN30A01 Central Air Conditioner
My outside condensing unit on my central air unit shuts dow when my thermostat is still calling for cold air. I have to shut down stat and breaker to unit and re start after an hour or so and the the unit...
My first guess is a dirty outdoor coil would give same symptoms you are having, high head pressure caused by the lack of air flow thru the coil, preventing proper heat rejection.
Jul 11, 2011 | Heating & Cooling
I have a ac central unit that has freon put in it, but it still blows out hot air inside the house.
Need a bit more info. Do you hear the compressor come on? Is your Tstat in the cooling mode? Shut it down for a minute and turn it back on. you should hear the indoor fan come on . outside fan come on and the compressor come on the sametime as the out door fan comes on.. Freon is just a gas that is used to exchange heat .
Jun 26, 2011 | Heating & Cooling
A power outage caused server to shut down. It
The power outage is suspected to corrupt the RAM. Get in touch with the vendow and get it replaced.
Nov 09, 2009 | HP Server Tc2120 (335874-001)
Central heat and air system won't shut off
sounds like tstat is wired wrong or possibly the contactor relay has fused shut outside. if you can stop the system from running at the tsat it is usually a problem with the t-stat
if you cannot shut off the outside unit without turning off the power at a breaker than usually the contact relay needs replacement
Nov 22, 2008 | Ruud UBHC Air Conditioner
Vulcan CX Central ducted heating. RE: Following a power outage the control panel does not respond, I have checked the pilot light and it is still on. I need to know how to reset the time and get it to...
The control panel gets its power from the central heating unit's power point. Try turning the power off outside at the powerpoint next to the ducted heating unit and try turning it on again after a few seconds, see if it resets
Jul 06, 2008 | Heating & Cooling
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
