Question about LG 47LC7DF 47 in. LCD HDTV
When I turn on the tv , it starts skipping/running through all the chnnels. At this point the remote does not respond and the only way to stop it is to unplug the tv. wait a little and plug back in. sometimes it works sometimes it doesn't. Once the tv stops skipping through the chnnels, the remote works fine. it is happening more frequently. tv is only 7 months old.
    Novelist:
  • 183 Answers
This could be a bug in the firmware. LG has a firmware upgrade which is loaded onto a USB stick and plugged into the HMDI port and the TV is reflashed. Try going into the menu and doing a factory reset. Just incase the TV has somehow gone into a diagnostic channel search mode. This may clear the problem.
Posted on Aug 02, 2009
My lg tv is stuck on chnnel 7. I can't change the channels.
try changing the channels from the tv buttons and not the remote control and if that works your tv has a faulty infra red remote sensor which is easy to replace if you can use a screwdriver
Sep 29, 2014 | LG 32LG30 32 in. LCD HDTV
Vizio TV remote controlling Altec Lansing iMT520 dock
Your Altec Lansing dock probably responds to some of the same remote codes as your Vizio TV. Your other TV probably used different codes.
Dec 29, 2013 | Altec Lansing iMT520 inMotion Classic Po
All programmed remotes stopped responding.
To turn off blue tooth on remote push the Q button, Space button and P button simaltaniously while pointing at tv.
Oct 15, 2013 | Vizio XVT472SV 47 in. HD-Ready LCD TV
I have lost my dish network remote but i have a universal remote i need the code so i can program my remote for my satilite
Here is a way with out the code.
1. Turn on the component (the tv, dvd, etc). 2. Press the TV (or DVD) button first and then the on/off button and hold both until the on/off button remains lit. 3.Press the PLAY button every five seconds until the component turns off.
  • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited
After the component turns off press the REVERSE button every 2 seconds until the device turns back on. Skip to step 7. 4.
  • If your television is an older model it may want to turn on immediately before you get the chance to press reverse. If that is the case and the TV automatically turns itself on then simply follow the step and keep pressing reverse until the component turns OFF. Then skip to step 7.
If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. 5.
  • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
6. To save the new code, press and release the STOP button.
Aug 24, 2011 | RCA RCR312W Remote Control
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Jan 02, 2010 | Philips Magnavox Learning Universal Remote
Can you tell me how to decode a grunkel dvd player to all regions?
Model 20-NT
1. Using the remote control, key in the following: Setup, Stop, Skip Backwards, Skip Forwards.
2. You should then be able to change region and remove MacroVision.
Turn on the DVD player without DVD inserted. Then, using the remote control, press this buttons: Setup, Stop, Skip Backwards, Skip Forwards.
Model 22NG
Turn on your player
Open the tray
Press 8 4 2 1 on the remote control --> "Region 2" appears on the TV screen
Press SELECT until 9 for region free & MacroVision free
Model 32S
Press Setup
press Volume +
Press Volume -
Press the right arrow until the screen on the player reads 255
Press setup to exit and all done
Nov 17, 2009 | Televison & Video
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Jul 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Need operating manual
if you are asking about the ” innovage” large tv remote… you do not need a code booklet.
maunally turn your tv on
point the remote at the tv
push ” code search”
a red button will blink
push the ” TV” button
then push the upper right botton with a circle and line on it…
the red burron will blink during each push…
at some point the tv will turn off…
push the “enter” button
the tv will then work with the remote.
it it takes too long to catch so to speak…
do not turn the TV off…
during the process… go ahead and push search code again..then TV
then on/off botton sometimes this speeds up the process.
i’ve found every once in a while the large remote stops responding to the on/off button…
just repeat the steps.
We hope this helps please rate/vote for me if it does thanks
May 09, 2009 | Televison & Video
TV not responding to Remote
needs fireware update call LG
Sep 22, 2007 | LG 42LC2D 42 in. LCD HDTV
TV not responding to remote
you can check your remote with a celular camera turn on the camera and point to the lens you most see the remote blinking if yes then wait for techman he will give you somes tips...good luck
Aug 05, 2006 | Samsung HCJ552W 55" Rear Projection...
LG 47LC7DF 47 in. LCD HDTV Logo
122 people viewed this question
Computer Repairing
Computer Repairing
