Question about Fuji FinePix E510 Digital Camera
I have exactly the same problem with the same camera
It was fine for a couple of years, this has only just started and I can't point to any installation or event that may have provoked this behavior.
I've tried reinstalling the drivers, rebooting the computer, turning the camera on first, then last but no success.
The MS camera wizard allows me to copy the pics so I know the cable is good but I can't Cut or Delete them from the camera.
I'd like to hear from anyone who knows how to fix this.
Thanks - rev
  • nicerev Aug 02, 2009
    I just solved it. You have to change the USB mode inside the camera settings. Enter the menu and pedal around until you find 'USB Mode' - then change it to the other setting, there are only two positions.
    rev
  • 10,421 Answers
My acer al2216w screen flashes black and white every few seconds. power light is on with no flashing
hi. check out put voltage of supply board. if it was correct check inverter and lamps.
Apr 26, 2015 | Acer AL2216W LCD Monitor
Lcd monitor clicking
Hello
According to your detailed description, there are two chanses for this fault. Either its LCD panel of backlight inverter baord has some kind of short circuit. Detailed troubleshooting should be done. It is a highly skilled work. OK.
Feb 07, 2012 | Computers & Internet
Have 380 SL not run regulary for several years but started couple of times a year. Fuel stabilizer and new fuel added yearly. Problem this year when took to the highway. Starts good and idles fine, but...
Sounds like a transmission slipping,if the engine
Rpm goes up & the car doesn't increase in speed
No fix for that, other than to remove it & have it built
Jul 16, 2011 | 1989 Mercedes-Benz 300-Class
I am using this camera from last 3 years. It was working fine. Suddenly, a problem occurred. Now whenever I select the Auto mode, it is set to video option instead of still image. I have formatted...
I'm have the exact same problem. Purchased the camera 3.5 years ago. Recently needed to shoot a video, when finished I set the camera back to Auto and it stayed in video. Portrait mode shows manual, all other modes work as assigned. I've noticed at least TWO other posters having the same problem within the last couple of months. It's as though this camera (mfg. 2007) has a Trojan program from the factory to make us buy newer models.
Other than resetting, is there a way to flush and reload the firmware?
May 06, 2011 | Canon PowerShot A570 IS Digital Camera
Sony DSC-P73 auto power off in picture mode
Hello!
You may try using any another compatible Battery pack in the Camera to ensure if the issue is not causing due to the Battery. Actually, when the Camera is switched to the "Picture or Camera" mode then the power consumption increases spontaneously. So, if the Batter is not holding sufficient charge to cater the power need of the Camera in the Camera mode then it'll automatically turn off. However, if the issue persists with spare Battery also then you may try resetting the Camera to the original factory settings by pressing and holding the Reset button for 30 seconds. Otherwise, it's required to get the Camera to resolve the hardware issues.
Aug 21, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Aoutofocus stopped working
Start off with the simple things, does it work with another lens, is the AF/M switch in the correct postion for autofocus (AF), are the batteries good.
If all of the above are in order it maybe either the DC/DC converter on the bottom of the camera, this supplies power to various parts of the circuit. or it could be the motor drive transistors, these are located under the front cover and are located where you finger tips rest on the right hand side as you hold the camera.
Both these items are not really user changeable and I know the DC/DC units have not been available new for many years now.
I suggest you have a look for a friendly camera repair shop to pin point the exact cause.
You will have to keep in mind the age of the camera 23 years old parts are a big issue
Sep 06, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Can't see anything
A couple of years back Sony had a recall on this camera because of defective image sensors. I called Sony and got an address to UPS the camera to and got it back 2 weeks later working just fine and got a couple more years of life out the camera before I got the 31:22 error.
Dec 11, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
Red vertical lines/no picture
Hi there. Contact sony service centre directly and ask them about replacing the ccd. I have a vx2100 which did exactly the same thing. Sony admits that there was a problem with the ccd's used in these cameras and replaced them for free, maybe the same for your camera. good luck
Dec 02, 2007 | Sony DCR-VX2000 Mini DV Digital Camcorder
Batteries Dying Quickly
Change the internal rechargeable battery.
Dec 01, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
Suddenly the batteries have started dying after 2-3 photos
did you try using lithim recharge battery i my self had the same problem with 1sd pentax ithout my camera was naced
Mar 25, 2007 | Olympus Camedia D-580 / C-460 Digital...
Fuji FinePix E510 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
