Question about Garden
I have a husqvarna 172 ride-on lawnmower. Running
I have a husqvarna 172 ride-on lawnmower. Running ok until i lower the deck and engage the blades. Then it's trying to cut out after 2-3 minutes of cutting. When i disengage the blades it runs again properly.
    Novelist:
  • 168 Answers
This unit probably has a safety switch built into it and it could be below the gas tank. If this switch isn't adjusted properly then it's designed to cut off the motor. I think you should concentrate on that before attempting anything else.
Posted on Aug 02, 2009
Went to start my tractor and found battery is dead. Jumped the battery and tractor started. I am going to replace battery. Question: My deck did not lower. Is this because the battery was not charged and...
No, the deck lowers by an entirely mechanical lever on the side with the notches for height adjustment.
Most likely the linkage is binding and needs cleaned of grass and possibly rust, then oiled.
However that model appears to have an electrical blade engagement system but that isn't relevant because if it is running which it has to be for the blades to turn, then the electrical system has power sufficient to energize the blades.
Oct 21, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
On my 42in cut hydro. Husqvarna, The mower will not disengage until the speed is reduced to a low idle
Before you do anything else check to make sure the blades are engaged on thier seat ( the star) and the blade bolts are tight.
If you have an electric PTO this does not apply to you.
After confirming that your blades are tight check the operation of the PTO cable and the pivot bracket by lowering the deck all the way. Laying on the ground on the discharge side of the mower you will be able to look at the components and see and touch whats not moving freely as you engage and disengage the PTO lever. Look for a stiff PTO cable, stiff pivot bracket, missing return spring, broken spindle brackets and broken deck bracket welds.
Of course you should never work on any mechanical device while it is running.
Oct 31, 2012 | Husqvarna Garden
My MTD riding lawnmower is burning thru the new belts I just purchased.The new belts are 954-0371A which replaces 754-0371A. The old style belt lasted 5 years. Even before engaging the clutch, the belt...
My idea is not about the belts, but is about the deck. If the tensioning mechanism on the deck is getting stuck in an intermittant position than the belt may be just tight enough to turn blades while slipping through the pulleys, this may cause enough friction to start melting your belts. If this is the case you will have to remove your mower deck and see what is preventing the mechanism from functioning properly.
Jul 07, 2011 | MTD LAWN MOWER PART 1909404 BELT
I have a husqvarna riding mower that when i engage the blades the engine stops running
Could be something jamming a blade or belt. With the engine OFF and the key OUT make sure the blades and belts all move freely by hand. Clear out all grass and c**p from the blade and belt areas. You may have to remove the blade deck to do this - instructions are in your manual or download a manual from the Husqvarna website. Good Luck!
Sep 07, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Aug 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Have a 48' 23 hp husqvarna lawnmower, it drives fine, but when I go uphill it slows down quite a bit. Why?
Same reason a person slows down when he is riding a bicycle up a hill?
Does the engine nearly die when you engage the blades on the fly?
If so you may have a dead cylinder, my 2148 would mow on the flat pretty well but not an incline with one cylinder. Cause of my dead cylinder was bent pushrods, which is not unusual on V-Twin B&S. You can test this by pulling one spark plug wire off at a time and running it.
Mar 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Blades slow down when cutting deck is lowered.
the lowerer the deck the more your working the mower. either mow more often or reduce speed
Oct 22, 2009 | Garden
Lawnmower loses power when I engage blades
This is most likely a belt problem. Check the deck drive belt that runs from the mower deck to the engine it/s come loose and got stuck between the guides.
Mar 15, 2009 | Garden
Garden Logo
164 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
