Question about Panasonic CT-36HL43 36" TV
Wont turn on
How do I change the fuse or check if the fuse is bad??
  • joedude Nov 26, 2007
    Thanks but could not find the fuse,This one has not rectangular piece of plastic, can I find the fuse. somewhere else???
    Scholar:
  • 43 Answers
Most moulded plastic plugs have a rectangular piece of plastic that sits inbetween the 3 pins. Using a flat bladed screwdriver you can prise this out and remove the fuse that sits underneath.
Best way to check if the fuse is bad is with a multimeter, however if it is a clear glass fuse you should be able to see if the thread inside is broken. Since fuses are so cheap you are as well putting a new one in anyway, however you must be careful to replace it with a fuse that has the same current rating. If you are unsure take the old one to an electrical shop with you and the staff will help you.
Posted on Nov 25, 2007
  • jonpitans Nov 26, 2007
    can you post a picture of the plug with the pins pointing at the camera?
Turn signals wont work bad ground
check the relay in the fuse box under the hood.
Oct 04, 2013 | Mazda MX-5 Miata Cars & Trucks
My turn signals dont work i changed the relay and it still wont work..
it is most likely not the relay but the flasher that is bad
Feb 23, 2013 | 1994 Dodge Intrepid
Turn signals wont work bulbs ok dont have a manual to the car dont know wich fuse goes to the turn signals
pickup a test light and check all the fuse if the fuses are good then you probably have a bad signal flasher.make sure you change the signal flasher and not the emergency flasher as they look the same.
Jul 30, 2011 | 1995 Ford Mustang
My turn signals wont work. i changed the fuses and checked the lights
Change the flasher unit, it's a cylinder type object, either blue or silver in color, usually in the fuse box, just pull it out and push in like a fuse.
The emergency flasher is the same shape, so don't cunfuse that with the turn flasher. To get the right one, turn on the 4 ways, put your finger on both of them, and whichever one you don't feel clicking is the turn signal flasher.
May 08, 2010 | 2003 Pontiac Grand Am
Heater or blower wont work in car just put in a
check all fuses if not that then you chould have a bad switch were you turn it on and off
Feb 11, 2010 | 2001 Buick Regal
Low beam headlamps wont turn on change bulbs and checked fuses and still wont come on.
did you check for a relay in your fuse panel? there should be a relay that controls your low beams and one for your high beams. check for that and then if high beams are working swap it with low beam relay. if your problem switches to low beams working and high beams not working replace the bad relay.
Jan 26, 2010 | 1998 Ford Explorer
Blinkers wont work
If they will work with hazzard lights turned on then you need a turn signal flasher,after you have checked the fuses of course.If that does'nt cure it then it's either the Signal light switch or bad wireing,but this is not common.
Oct 23, 2009 | Ford F-350 Cars & Trucks
1990 honda accord wont start
Your Starter is Bad. Change it out and you should be Just Fine on Starts.
Jan 21, 2009 | 1990 Honda Accord
Royal orca wont forward will reverse shredd.
May have paper bits jammed above fixed curved metal surface that spiral cutter slices against.  Need to spend time removing built up material with stiff wire or flat tool.
May 04, 2008 | Office Equipment & Supplies
Panasonic CT-36HL43 36" TV Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
